2530 off, fmic is ok if you haven't cut into the reo bar, or chassis, and it is secure, secured pod is fine as long as it is secured tight, 3'' exhaust will probably have to go as it will be too loud, power fc will have to go, for safety sake the boost guage will have to go, as it is probably in the line of sight, 555's regency may just pick on, fuel pump is ok, afm will need to change as you will be taking out the power fc, boost tee has to go, and nardi steering wheel probably isnt ADR compliant so that has to go.
Good luck!
Aww man thats the biggest headf**k ever
can the power fc controller just be removed and the ecu left alone or does the whole thing have to come out?
defects suck (N)
quick question, dump pipes allowed?
mate just went through with his 3" dump pipe and cat on, but with a factory system from the cat??
you can go through with a full zorst as long as it is under the legal DB limit......i went through with mine just had it quietened down and presto.....so the exhaust size doesnt matter...
will a s2 turbo pass through regency or will it need to be the s1 r33 turbo?
I think your series 2 turbo should pass fine as they look identical externally and it is a factory Nissan part. But make sure all factory boost lines are in stock positions and you are not running any bleed valves or T pieces or ebc. Just run the factory boost solenoid wired on standard mode not on high boost mode all the time. And all should be sweet!! good luck :P
They dont take the cover of the ECU to see if its stock. but they do now look for holes for the hand controller. thats how they got me last time I went through. If they find that they automatically think you have a Z32
Good luck!
injectors will have to come out as the stock ecu cant run them.. unless u get a remap but thats $500
OR you could try putting your stock ecu cover over the top ond the power fc one and try your luck.. then afm, injectors can stay in..
they may or maynot check it..
i have been through MANY times and not even checked the ecu!
when i took my skyline through, i had my high flow on there with no heat shroud.. fmic full 3" tien high adjust AND PASSED!
they arent that picky.. they just check if roadworthy mainly unless suspicion of engine mods
Yes... they are. You got lucky
Rang up today to book my car into regency and was told that a new place at Lonsdale is opening up to clear defects on Wednesday's and Thursday's so i've got my car booked in for next Wednesday. Hopefully the guys who work there are chill.
Yeah def let us know how it goes!
Us down south need a place this way to get us off defect!
Hey, im taking my down to Sinergy for a pre inspection, but the rego has run out. Do i have to get a permit to drive it there or should i be fine.
Yep you definitely need a permit mate.....just do it on the day of your inspection and get the permit to go to sinergy first then to regency and back home .....if not the refer to VVVV
if you're thinking of driving it there unregistered, i hope you carry a spare jar of vaseline with you.
Just a quick question will a vg30 turbo pass regency as i really dont plan on doing this all again and rather have a hiflowed vg30 as opposed to a 2530?
Cheers, Chris
Yep it should pass without a problem mate....its a Nissan OEM part so not defectable....one would assume...
hmmm i think they will know that its not a stock skyline turbo.....
Nissan OEM parts are not illegal to have :P
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
