I think its because they believe its unsafe to have your car engine running whilst not having to have a key in the ignition, i.e. a car whose engine is running that is unattended and unable to be turned off immediatly if required.
I am not sure why this is a problem mate, just what Ive heard.
got defected for track and a turbo timer the other night which sucks, just wondering why the hell a turbo timer is defectable? anyone know? i mean they add absolutely no perfomance and they come out standard in trucks.
turbo timers are useless in passenger cars.
learn how to drive easily for a few kilometres or idle your car for 30-60 seconds when you park. not that hard.
its been covered about 4,000 times why theyre not legal. just search for 'turbo timer'.
hey guys my mate just got defected (regency), hes got a pretty nuts chaser and were looking at his options now. if you could help out with providing maybe a chaser forum you know or sumone willing to lend sum parts will be awesome.
this is wat the car has:
forged motor
t67 turbo
external gate
greddy emanage
blitz electronic boost controller
full origin body kit with vented front guards
all around greddy coilovers
reclinable bucket seat
these are just some of the major things that we think aint gonna let the car pass
the car is immaculate so hes pretty devo and its too nice to turn it into a track car. :domokun:
hes just not sure on costs of having to buy stocko parts to put on. so were thinking of maybe selling it as is or swapping it for sumthin he can use cuz hes sick of it being defected.thats if we cant find ne1 2 maybe lend out sum parts.
go to a few importers or import wreckers, most are willing to help out with lending parts
Edited by SkyHi_33
Or if you can't/don't want to do it yourself. Take it down to a place like Sinergy or JMS and get them to take the car off defect for you
thus is true. cost a mate $1200 to get synergy to get his car past regency and it was VIRTUALLY stock. its costly but you knw the car will come back in one piece and past first time evrytime.
i personally would use JMS. synergy just rip ppl off
does anybody know if a aluminium radiator will have any problems goin through regency? (JJR aluminum radiator just for the record). or an oil cooler?
they shouldnt. neither are performance or structural mods - both are for engine longevity.
-D
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
