hey guys just got cained in the pits :huh:
got booked for being 20 mm too low, changed everythng over but i didn't clear it cos the peanut i bought the car from dented the chassis rails when he jacked the car up.
can anybody recommend me a place to get this done, is it a mechanic or panel beater job?
cheers guys
Well you can't have it on the pillar, on the dash above the steering wheel, behind the steering wheel on the column or below the dash where your legs are, as these are all 'crash zones'.
Legally, just throw it on the centre of the dash like what some HSV's or FPV's have... That's legal. Otherwise you'll get hassled.
mines on top of the steering wheel column in front of the dash but not obstructing the cluster. Been through regency 3 times with it, no problems. even had one inspector shake it to make sure its bolted down...
mind putting a pic up?
curious to see where exactly it is lol
booked in for regency this friday at 10 am. ill be getting my old man to take it through, yup, im playing the parental unit card.
stock suspension is in, stockish wheels (with brand spankin new rubber) are on, borrowed a standard exhaust and fitted that along with my standard cat, standard boost solenoid is hooked up, diff has been cleaned to within an inch of its life, gonna give the engine bay a degrease and spray today or tomorrow, then im off. fingers crossed.
Thats where mine are. He was about to tell me to take them out on the spot but then noticed the velcro and said they are fine.
So i guess u can have them on ur dash. I just carry around my old defect notice if anyone asks.
Hey luke bit of topic but what brand gauges do u have and they are 60mm ye?? I need to buy some for my gauge holder on my pillar but i can only fit 60mm, and urs look sweet i have been looking for the same colours.
Edited by wnted1
what other gauges are you running? 34's already have speed, RPM, oil pressure, oil temp, water temp, boost, volts
passed relatively trouble free. only faults were the seatbelts not retracting properly, but he was happy with those because they still locked when he yanked on them.
and the windscreen washer which worked perfectly when i checked everything this morning didnt work come inspection time, but the inspector put that down to water restrictions. :domokun:
dude was a f**kin champ.
he laughed at the boost gauge defect, but the reasoning he gave for the wheel defect was pretty sound. apparently people have a habit of taking to their wheels with a drill press to make them fit, and considering some of the calls ive had about my wheels, im not going to dispute that.
and the windscreen washer which worked perfectly when i checked everything this morning didnt work come inspection time, but the inspector put that down to water restrictions. :D
where is your gauge located?
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
