How much to get that done?
Same price as all his other OP6 high flows I imagine, around the $1500 mark I think.
A 260kw highflow using OP6 rear end would be the best performance highflow he does using the stock housings.
std high flow would has the best drivability which cost $960 inc GST and braided oil line or use PU high flow that also capable of 300rwkws cost $1400 with a brand new .82 rear housing and actuator.
The 3540 sort of high flow cost $1200 using all stock housings, I didn't like they way how it drives, its very laggy.
  • 1 month later...
Hey everyone.
Got some questions regarding vehicle defects
I recently parted with my hard earned on a 1998 40th anniversary R33.
The previous owner said the car was imported in 2008 and that he bought it 2 months later from a dealer
It has tein adjustable coilovers, which he told me were a defect (i knew that before i bought it) as well as the boost guage located on the drivers side door piller and a Greddy boost controller(Which is now removed).
He then told me that the car was imported in its current state.
This confused me because the car would have had to pass through Regency before it was able to be sold.
WHY did the vehicle pass with clear breaches of the rules and WHY did the dealer then proceed to sell him the "Unroadworthy" vehicle, it makes no sense
I am also hazy on the BOV regulations. Are aftermarket BOV's defectable alltogether or are they legal if the pressure is plumbed back into the system?
Cheers
Slack inspector is basically the only reason it got through, the majority will not pass adjustable coilovers.
It is possible they paid a workshop to comply it and get it registered, workshops will put 100% stock gear in, get it registered then swap all the mods back on.
The latter is much more likely.
I had the same issues with mine, A pillar boost gauge , coilover shocks, dump pipe from dealer , who knew it was defects but didnt care. just wanted the cash. they put all stock gear on it then swapped it over afterwards
mine went thru regency without a buckle on the seatbelt and they didnt catch it. .. safety inspection my ass. I caught it the day I bought it. test drive , no way to secure the belt.the part wasnt there at all.
  • 3 weeks later...
Hi Guys,
Just wanting to know if anybody has had any answers to know if aftermarket turbo's (GT2860-7) will pass through without any hassles on a 33R?
Thanks
At a visual inspection do they look identical to stock turbos? If not then no it will not pass.
Remember they will be looking from above and from below. Do they have tags on them which indicate they aren't factory nissan? if so remove them. Any markings, numbers or letters on the housings may be a give away, grind them off and then grease it up so it doesn't look brand new imo.
Hi Guys,
Thanks
They >should< pass, whether or not they pass without hassle is another thing (depends on the inspector) - you >may< need a document that declares that the 2860 series are a direct bolt on replacement for the OEM turbos (I believe MTQ has these?)
Good luck
-D
I reckon they would get through, they look the same, same size and no modifications to fit. and you can barely even see the turbos. I think if u look hard enough, at one angle with a torch you can make out the word Garrett
Good luck
-D
Thanks for the reply guys, I will give MTQ a call tomorrow and seek a bit more information.
I have it booked in for inspection at Regency on Tuesday so hopefully the car passes without any massive problems.
Once again thanks for the help!
Josh
they aren't going to boost more than your current boost controller so their levels should be the same
but their airflow at the same boost will be greater, hence different load points?
I am assuming they have different trim wheels.
In most cases yes, but that also depends upon the PSI rating of the actuator attached to the turbos
Garret make em in 7, 14 and 21 psi...
All are legal (but never as accurate/safe as an EBC, therein lies the dilemma)
-D
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
