A lot of us do drive like dicks at times, if you saw a commodore pull out of a sidestreet and hang the back out for no reason doing 80 in a 60 you would laugh when he got defected. Even if it was 11pm on a Tuesday with no one around.
When you are honestly doing nothing and get done then I can see where the anger comes from.
+1
sorry didnt mean for that comment to anger people, im all for spending a bit of time and money to make a car look good but when people drag race and kill other people it ruins it for others and what happens a blitz on all imports even if there are more rust buckets out there but thats a never ending story. reality is one day we wont even be aloud to have a cd player in the car without getting a defect :/ life sucks :(
bottom line is there are always people out there who are going to ruin anything for everyone else and we are all the unlucky ones
"bottom line is there are always people out there who are going to ruin anything for everyone else and we are all the unlucky ones"
yep :(
Bit confused what regency meant by "child restraints" and how to actually fix it. Since i have after market rear speakers (6" clarions) sitting in the parcel shelf of my r34 gtt coupe, what do i need to do to rectify this defect?
I do know the stock speakers have holes going straight through them to the mounting points. Not sure what to do here, any help / advice?
Do you have the mounting points for the child restraints already fitted? If so you don't need to do anything, this should have been done when the car was imported.
Regency had a go at me because I didn't have the actual child restraint hooks, however if you have the anchor points this is all that is needed, they can be fairly hard to see and find but if you have them then this is all that is required.
I knew this day was coming. So here it is, I got DEFECTED last weekend in Berri. I was driving my mates car and he was driving mine. He got pulled over, I kept going. He called back saying that the cops wanted me to bring his car back so that they can have a look at it and possibly defect it as well. When I rocked up the first thing the cop said was "your car is being defected". So instantly I asked why it was being defected for, the older cop said, for BOV, boost controller and aftermarket turbo. All is fine but the BOV is stock, and the boost controller he pointed to my Master brake cyclinder stopper.
Being defected wasn't an issue, the issue for me here is that the cop told me that I was getting a fine for driving my mates car which they deemed defectable. So I would get the fine for being the driver at that time and my mate would get the fine for driving my car which was defectable. This is where I have a small issue, I got a fine for my car for not complying with ADR standards and a defect, but on the other hand my mate didn't get a fine or a defect. So this is what I am confused about? I wasn't the driver of my car at the time of being pulled over and defected. Yet the fine has been made out to me.
Can anyone please clarify this for me?
Lol you guys have never done a skid before? Rose coloured glasses anyone?
haha
NO - Ive never done a "skid" before.
Never, not once since I got my L's on my 16th birthday 18years ago.
My poison was "going fast" back when I used to ride bikes, so I know Ive done wrong previously, however that being said, I dont go over the limit simply because I couldnt afford to pay out a speeding fine! That, and with the fear of defect, my Stagea is for sale.
Krishy - sorry to hear mate. Thats not good :(
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
    • I was chatting with an ex SAU person who is involved in chooning euros now. He was saying the factory cars like Audi VW etc have something like 2000 tables that the ECU uses for getting everything "just right". Compare that back to any aftermarket ECU, and you'd be hard pressed to surpass 50 lookup tables. Even the Ford Barra engine has a few hundred lookup tables to run it (and they're still working some tables out too!)
    • Grab a temp probe, and probe each exhaust inlet runner with it sitting idling. Each one should be pretty darn close to the same temp. If you've got some reading higher or lower than the others, it's likely either air flow isn't equal, or your injectors aren't equal to each other.   The other things to check, is from the wiring changes that were made, were any earth's or grounds moved/changed.   Lastly, for the strut brace issue. It's not perfect, but can you get away with slipping a washer or two under the strut brace to raise it, and it still clean the bonnet? If you can, work out the height you need, that the motor can't torque up into, and get a spacer made for each side.
