How much to get that done?
Same price as all his other OP6 high flows I imagine, around the $1500 mark I think.
A 260kw highflow using OP6 rear end would be the best performance highflow he does using the stock housings.
std high flow would has the best drivability which cost $960 inc GST and braided oil line or use PU high flow that also capable of 300rwkws cost $1400 with a brand new .82 rear housing and actuator.
The 3540 sort of high flow cost $1200 using all stock housings, I didn't like they way how it drives, its very laggy.
  • 1 month later...
Hey everyone.
Got some questions regarding vehicle defects
I recently parted with my hard earned on a 1998 40th anniversary R33.
The previous owner said the car was imported in 2008 and that he bought it 2 months later from a dealer
It has tein adjustable coilovers, which he told me were a defect (i knew that before i bought it) as well as the boost guage located on the drivers side door piller and a Greddy boost controller(Which is now removed).
He then told me that the car was imported in its current state.
This confused me because the car would have had to pass through Regency before it was able to be sold.
WHY did the vehicle pass with clear breaches of the rules and WHY did the dealer then proceed to sell him the "Unroadworthy" vehicle, it makes no sense
I am also hazy on the BOV regulations. Are aftermarket BOV's defectable alltogether or are they legal if the pressure is plumbed back into the system?
Cheers
Slack inspector is basically the only reason it got through, the majority will not pass adjustable coilovers.
It is possible they paid a workshop to comply it and get it registered, workshops will put 100% stock gear in, get it registered then swap all the mods back on.
The latter is much more likely.
I had the same issues with mine, A pillar boost gauge , coilover shocks, dump pipe from dealer , who knew it was defects but didnt care. just wanted the cash. they put all stock gear on it then swapped it over afterwards
mine went thru regency without a buckle on the seatbelt and they didnt catch it. .. safety inspection my ass. I caught it the day I bought it. test drive , no way to secure the belt.the part wasnt there at all.
  • 3 weeks later...
Hi Guys,
Just wanting to know if anybody has had any answers to know if aftermarket turbo's (GT2860-7) will pass through without any hassles on a 33R?
Thanks
At a visual inspection do they look identical to stock turbos? If not then no it will not pass.
Remember they will be looking from above and from below. Do they have tags on them which indicate they aren't factory nissan? if so remove them. Any markings, numbers or letters on the housings may be a give away, grind them off and then grease it up so it doesn't look brand new imo.
Hi Guys,
Thanks
They >should< pass, whether or not they pass without hassle is another thing (depends on the inspector) - you >may< need a document that declares that the 2860 series are a direct bolt on replacement for the OEM turbos (I believe MTQ has these?)
Good luck
-D
I reckon they would get through, they look the same, same size and no modifications to fit. and you can barely even see the turbos. I think if u look hard enough, at one angle with a torch you can make out the word Garrett
Good luck
-D
Thanks for the reply guys, I will give MTQ a call tomorrow and seek a bit more information.
I have it booked in for inspection at Regency on Tuesday so hopefully the car passes without any massive problems.
Once again thanks for the help!
Josh
they aren't going to boost more than your current boost controller so their levels should be the same
but their airflow at the same boost will be greater, hence different load points?
I am assuming they have different trim wheels.
In most cases yes, but that also depends upon the PSI rating of the actuator attached to the turbos
Garret make em in 7, 14 and 21 psi...
All are legal (but never as accurate/safe as an EBC, therein lies the dilemma)
-D
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
