Guys, would a forward facing plenum on an rb25 pass regency?
Of course there are injectors and TB to take in to account, but if the injectors are the same or atleast the same size, and original TB used?...
They usually say as long as standard injection and emission gear is in place you are fine. Call them up and ask, provided the injectors and everything else is standard you should be ok.
Technically as soon as you change runner length you effect emissions, but so does a FMIC and they let that slide.
Got done on Saturday night for 20mm too low, is it worth me changing out my sard injectors and nismo afms? Also my taillights are LEDs but still retain the factory reflectors, is it worth changing them too?
Dude spent well over 5 minutes with a flash light looking at the fuel rail, injectors, intake manifold, vacuum lines running to everything etc when I went through, though I had gone through with an engine swap that specifically mentioned "standard injection systems retained" on the application so he might have been a bit more anal.
If you can be f**ked taking the rail out painting the injectors stock colour is easy to do, just go visit a model shop and match the colour, cost you like $10 for a brush and some paint.
Assuming of course you have stock looking injectors and not something with adaptors sticking out all over the place.
With the AFM just peel the green sticker off a stock AFM and put it on there, easy as.
Edited by Rolls
people do it with adaptronics and a few other ECUs quite regularly, they come with a plug in loom connector so I unless they unscrew it they'd have no idea.
Unless you run MAP and they unplug the AFM, but I doubt they are going to bother doing that.
or swap your pfc into a stock body ;) ;)
was gonna do that, but probably just as easy to change afms, injectors and ecu. its not like thats much work
what are people thoughts on my tail lights?? this is what they look like up close
I have similar lights and I went through regency 3 times to get my car right they didnt even touch the lights.
Also the ummd and rrrrrd about the nismo intake but i didnt have to change it :thumbsup:
They DO (or have) done that, known a fair few that have got caught, and that was 6+yrs ago..that import guru that they got in yrs and yrs ago to work at regency used to do it (does he work there anymore?)
cheers
darren
Edited by jet_r31
    • I normally run with I think a 10mm, and definitely use the second handle you can add to a drill. They hurt when they bins up!   For the crush tube, once all subframe is clear, I'd try some stilsons and see if I can get it to start to twist.
    • Probably because they couldn't, because the use of the variable resistor to create a "signal" in the ECU is managed by the ECU's circuitry. The only way that VDO could do it would be if they made a "smart" sensor that directly created the 0-5V signal itself. And that takes us back to the beginning. Well, in that case, you could do the crude digital (ie, binary, on or off) input that I mentioned before, to at least put a marker on the trace. If you pressed the button only at a series of known integer temperatures, say every 2°C from the start of your range of interest up to whatever you can manage, and you know what temperature the first press was at, then you'd have the voltage marked for all of those temperatures. And you can have more than one shot at it too. You can set the car up to get the oil hot (bypass oil coolers, mask off the air flow to oil coolers, and/or the radiator, to get the whole engine a bit hotter, then give it a bit of curry to get some measurements up near the top of the range.   On the subject of the formula for the data you provided, I did something different to Matt's approach, and got a slightly different linear formula, being Temp = -22.45*V + 118.32. Just a curve fit from Excel using all the points, instead of just throwing it through 2 points. A little more accurate, but not drastically different. Rsquared is only 0.9955 though, which is good but not great. If you could use higher order polynomials in the thingo, then a quadratic fit gives an excellent Rsquared of 0.9994. Temp = 2.1059*V^2 - 34.13*V + 133.27. The funny thing is, though, that I'd probably trust the linear fit more for extrapolation beyond the provided data. The quadratic might get a bit squirrely. Hang on, I'll use the formulae to extend the plots.... It's really big so you can see all the lines. I might have to say that I think I really still prefer the quadratic fit. It looks like the linear fit overstates the temperature in the middle of the input range, and would pretty solidly understate what the likely shape of the real curve would say at both ends.
    • I got a hand held bisssel one and it's a piece of shit. Doesn't work for more than about 5 seconds. So much so that I nearly refuse to believe any wet dry vac actually works or has enough suction to clean the carpet of a car. I'm discouraged as all the good ones are $300+ for an unknown result. I saw MCM did a Ryobi video where they use this thing: https://www.ryobi.com.au/products/stick-vacuum-cleaners/18v-one-hptm-brushless-spot-cleaner-tool-only Anyone have any experience actually using a tool like this when not paid to showcase it?
    • That could very well be the thermistor, but the ECU only sees Volts. VDO don't seem to provide a 0-5 volt curve, only the resistance curve.... (or line).
    • Yes. Probably, given that there is only access from the bottom end of it, go with a drill bit. Don't start too small. 7 or 8mm is probably the right size. You want something that can make a big enough hole to do some damage, but not so bit that it clashes with the steel or binds up and breaks your wrist. A slow speed is probably a good idea too. Once the rubber is destroyed, you then have to get the crush tube off the stud, which will be the whole heat/oil/cutting exercise all over again, but this time with the need to strictly avoid damaging the stud (any further than the corrosion might already have done.
