^^ Danny with age like that on your side you may need to retire and mod down to a RB25DE hahaha
The elderly and turbos do not mix unless attached to a 2.5L Diesel towing a caravan ;)
On another note when is the next wreck coming in???
  • 2 months later...
I got defected by a wanka cop for bov, blue parker lights and low beam turning off when high beam is on which is factory stock not a wiring problem he also thought the turbo timer was a boost contoller! the cop then said i have a week to take it to regency! I explained i only just bought the car 3 dsys ago and was gonna change the stuff! I asked why i couldn't take it to a cop to get the deffect off! He said caus there not mechanics they don't kbow what there looking at! I asked if he was a mechanic he said no then i said well how do you know what your looking at! He then ssid get smart with me ill arrest you an fine you 500 for driving a deffecable car i said you can't do that!
turbo timers are an instant defect, illegal on sports cars and they're a waste of money. well they can fine you $150 dollars for each defect they find. there is no set time frame you have to "get it to regancy" even if it runs out of rego just get a day permit.
To the guys out there that run a greddy intake manifold, have you even been defected for it? Or can you get defected for it??
Cheers
Get an idle emissions test and send in an application to modify your vehicle, they will come back saying you need an emissions test, once you have that you can go to regency to have it inspected and then you will get a nice piece of paper to put in your glove box saying you are A-Ok, if not then you are up to the mercy of the cop.
Actually even with the piece of paper you are up to the mercy of the cop.
You can get defected for your exhaust not looking standard, you can get defected for things that do no even physically exist on your car so if they want to defect you, they will.
Basically if you draw the wrong sort of attention, guaranteed defect no matter the condition of your car.
Edited by Rolls
Just play the game as best you can and don't drive like a dickhead and more often than not you will be fine. I got an application to modify my car with all my mods listed, idle emissions test and keep the inspection record in my glovebox, if your car looks stock, you show them this and don't act like a twat you'll be fine the majority of the time,
    • Are you suggesting that the kit did a cheap and nasty job of just jamming the wheel in between other things and caused the misalignment? I mean, we normally do this with an integrated crank trigger wheel, not something bodged on. It's not 1995 any more.
    • I mean, given the number of BMWs you own their tolerance for improper torque is rather low. The number of torque + angle spec bolts and non-reusable bolts in one is nuts.
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
