Hi everybody
Got a "defect warning" last night for "engine oil leaks" I am new to SA and also on my p's which didn't help my case of getting pulled over in a r33 n/a( cop was hoping to find a turbo).
So my question, is it anything to be worried about? As in am I going to pulled over and checked for the warning in future? I am only worried due the fact I had a look in the day light and couldn't see any specs of oil anyway I even jumped on the car and looked up and still couldn't see anything so I'm worried they will just keep "finding" "leaks"
Okay, can I have an external wastegate if it is plumbed back?
Where am I able to mount my gauges legally? can I use those 2 hole gauge pillar that sits next to driver?
And wow, defected for oil leaks? I guess it's true that you can't have an UNdefectable car, aha..
Kinda sucks :(
external wastegate = no idea but cannot see it being allowed through even being plumbed back.
gauges have to be mounted below the top of your dash line from memory, so the 2 hole gauge pillar is a no go (correct me if I am wrong, but know of a mate who got defected for these)
Cheers guys, cleaned up the engine bay and found hose's to the pump and also to the rack are leaking some where along line, thankful the cop wasn't a douche bag and just gave me a warning. And cheers for the info guys
last i knew is guages had to be below the top of the steering wheel. Funny how this can be the case as now 90% of cars have GPS's etc stuck on to the windscreen with a suction cap and this seems to be ok, but fixed guages are a no go. ive seen a square guage setup that uses the OBD2 port and looks the same as GPS so these may be an option??
  • Like 1
Um interesting, I got told it had to be below the line off the top of the dash.
Yeah just goes to show how much import owners/drivers get picked on. You can securely mount a few gauges without any issues, yet can get defected for them. On the flip side you can have a poorly mounted GPS in the middle of the f**king windscreen and its considered perfectly normal and won't get picked on for. Where is the justice :(
Kinda sucks :(
Nope, you can't have external gate or any turbo other than the stock turbo, all change the emissions and hence are defectable. If you want to run an external gate legally hide it under the exhaust shield so no one can see it, or spend $2k getting a full spectrum emissions test done, though if you are going to do this you might as well change the turbo, injectors, ECU and everything else, as if you can prove the emissions meet what is in the car then you can get it legally engineered.
  • 4 weeks later...
after owning the car for 3yrs now i got my first defect for ground clearance being 80mm not 100mm
after going for my first inspection i soon realised the whole car gets inspected..lol
here are my stupid question..do n1 one turbo pass as standard turbo for r34 gtr cause atm i have trust t51
i have hks fmc piping kit with hks bov that vent to the atmosphere.. do i just buy factory bov and do they just bolt straight in and plum them back.
why can you have a fmic that increases air flow but cant have greedy intake plenum chamber that does the same thin
after researching sa transport i now know i need the coil overs and after market front seats engineered has anyone been through this process yet.
z32 afm are they aloud or do i just find standard afm
thanks for any advice
n1 turbos will pass
get some standard bovs and plumb them in like youve said
cooler piping shouldnt be an issue if youve got a standard front mount and plenum (i went through with nismo intake pipes)
z32 wont pass, need standard (i got through with nismo's coz they look standard)
engineering coilovers can be done but seats cant unless theyre adr approved (so brides are a no no)
basically none of that will pass unless you spend thousands of dollars engineering the car, what I would do is go back to stock intake plenum, stock exhaust manifolds with -5 etc twin turbos (oem replacement with bigger wheels), standard AFMs, retune with a stock ECU with nistune.
You can't use Z32 for 2 reasons, 1 you have a single turbo conversion (will never pass), and 2 it didn't come with a z32 afm. You could get a green sticker for the afm but as you need to go back to twins I wouldn't even think about this again.
The FMIC vs intake argument is sound but regency will never agree so don't bother going there. Coil overs that are adjustable cannot be passed unless you have a perch welded onto them that makes them above or equal to legal height, as you probably don't want to do this install stock suspension to pass.
Seats unless ADR approved cannot be passed unless you pay an engineer to figure out if it meets ADRs and write up the appropriate paper work.
Bov must be removed and all standard intake piping put back with the stock twin turbo intake/exhaust.
I'm guessing you also have aftermarket ECU and injectors, all of this has to go as well and go back to stock, the best way to get through regency is with a nistune in the stock ECU and injectors that are painted the same colour as stock.
The final option is pay someone to swap all stock gear in, pass it at regency then put all your gear back, but this gets expensive if you have to do it each time you get defected, I would instead do as mentioned above and covnert back to -5s etc twin turbos.
Welcome to the game that is modified cars, gets expensive fast.
  • Like 1
Thanks rolls. I still do have twins trust t51z std intake pipes..I'm going to contact one of sa transport recommended engineers and talk about the coil overs and seats and try get them engineered. the rest ive nearly sourced all the std stuff, turbos afm bov and already have std ecu with nistune just need to unplug my pfc I hope I just limp there lol
    • Not that I know from experience, but in theory you'd want your gate spring to be as close to target pressure as possible, so you'd go with the higher gate spring?
    • Before I commit to it as I already have the wastegate off the car, would you change it to the 9psi spring instead of the 12, or whack it back on now and try your suggestion?   Edit: Actually I might just swap the spring and see what the logs say after another few pulls, as we know it's still spiking without the Mac valve in the picture so I need more data without the Mac valve trying to combat the issue.
    • Sounds good Hmm suppose the main thing is, how much do you care about this car? The filler doesn't make for a very good water barrier lol. If there was a tiny little bit of rust forming now, that in 3 to 5 years time becomes obvious under the paint (starts to bubble up), would it bother you?
    • I already have the ability to datalog the voltage... what I can't do is correlate it to what the gauge is showing when I'm looking at the data at a later date. Or something like this. Except getting the oil to 125C+ involves me going 200+kmh at the track so you can imagine this is a little tricky unless I do something like note what the voltage is when I am at the top of 5th gear so I have a point to reference on. Drove car today. O2 still reading richer because hopefully not a leak instead of massive restriction I've introduced. Car really doesn't sound like a LS. It's quite strange. Pulled a bit of fuel out up top. This does potentially explain why my spark plugs looked like the car was running pretty over-rich. If I was tuning it to a ~12.7 which in reality was far richer than that in the past. It will be handy to have the dyno WB to compare my WB to to compare notes that's for sure. At this point I'm happy to just sit in the passenger seat and tune the thing given I've got about 7 million hours on the platform lol.
    • Yeah I understand you have to pay for an updated map or subscription service or something. But I can't even find a current map for Australia. My map is dated 2017, but didn't this car version still sell in Australia until 2021?   Also, just as an aside, the navigation system warns you of traffic incidences ahead.....why would they include that on a map they knew is not receiving live information. I am forever going to be warned of an incident that probably existed for 30 minutes 8 years ago.
