hey boys and girls
yes i got defected last night for a ebc prob 5 mins from my house lol
the cop followed me from holden hill
i was returning after soccer..
my skyline isnt a daily so not really fussed all about it
going to take some flexi time today and rip the ebc off and take it to the cop shop so that i can still drive it
but yeah another trip to regency...lucky got all stock parts for it
ahh well these things are bound to happen
just a matter of when really
there was way too many cops out last night....specially on a tuesday night
the guys that pulled me over were very nice
had a 5 min chat with them etc etc....he even old me what to use to clean my headlights
apprently he uses that on his bike and it works a charm
was your EBC hidden? did they find it on the interior or in the engine bay?
-D
i was defected for an ebc as well. was there anything that they overlooked though on your car?
I don't think he'd want to go saying on a public forum. :)
Edited by RubyRS4
Once they find one thing, they usually wont bother continuing to look.
If you get defected for 1 thing, 90% of the time, you have heaps of other defectable items.
Nah apart from that the car is pretty stock mate
That is so damn true
On my defect form it says that the defect is minor
yet it needs a full inspection? i just dont get it
couldnt this be a cop shop thing...where it would save me time and the hassle of it all?
If its a minor defect you can remove the EBC and get the defect cleared at Sturt. Do it, it'll save you $$$
-D
well i took half a day off yesterday as flexi time and riped the boost controller out
went down to the cop shop and the officer there had no idea but wanted to see where the boost controller is
so i showed him what i ripped off and it has clearly labelled "Boost control valve"
he was happy with it and signed it off so now i can drive the car till 9th of april - 2pm
the regency appointment is at 9th of april - 1pm
good little bit of info:
http://www.lawhandbook.sa.gov.au/ch10s08s04.php
Be sure to read the "A defect notice MUST contain:"
I believe that if your defect notice fails to mention any of the criteria, you can take it to the police station to be cancelled?
It also says that a minor or major defect may be issued if:
"If further road use would cause imminent and serious safety risks then a major defect notice is given; in any other case a minor defect notice is given. In which case the notice is to be given to the driver, the defect label is to be affixed to the vehicle, and a copy of the notice is sent to the Registrar of Motor Vehicles."
I don't believe an ebc has imminent safety risks.
And heres part of the road traffic act - enforcement - defect notices:
A police officer or an authorised officer may for the purposes of examining a vehicle
under this section—
(a) cause the vehicle to be examined by any other person; and
(b) drive or test, or cause any other person to drive or test, the vehicle.
Road Traffic Act 1961
I got defected for my wheels hanging out of my guards, marked down as a minor. Took it to the cop shop at Henley and they basically said to bad you have to go to Regency. If it is marked Regency even if it was minor, you have to go. Kinda bullshit because that is blatant revenue raising at its finest.
The Defect:
R33 GTS25t S2
7.35pm 20/1/09
Hill Street, Campbeltown
Minding my own business in heavy traffic, not boosting
Sent to regency (major defect)
Was given 72hrs to drive car normally, after that only to and from places of repair/picking up parts
Once I had fixed the defected items, Holden Hill Cop shop checked it and I was able to drive until inspection
Done For:
Atmo-BOV
Cracked Headlight
What I did to prepare:
Replaced BOV with factory item (bought from PSI Parts over forum)
Replaced metal intake pipe with silicone item with correct plumback piping
Replaced headlight with used one from adelaidejap wreckers
Removed Turbo Timer
Removed Boost Gauge
Replaced Battery with RAA sealed calcium one
Fixed some minor coolant and oil leaks (done at Morpowa in modbury)
Gave the car a THOROUGH clean and detail, including hours spent in the engine bay
Dressed neatly for regency, and tried to be polite and well spoken
The Regency Visit:
12/04/09
Passed First Time
$137
Mentioned Tyres we're getting a bit low but said they were ok
Said my battery was the incorrect type, but wasn't going to fail me for it (so he was wrong, or the RAA book is wrong...I'd back the first one)
Non-Standard Items that got through:
HKS Super Power Flow Intake (Pod Filter)
Cat-Back Exhaust
FMIC, cut reinforcement bar and cut sheet metal for pipe work
17" Enkei Rims, well inside guards
    • Hi Apex and welcome!
    • Probably too late to reply to this, but worth a try. It's not calliper flex, the calliper as a whole is moving so it has to be calliper mounting bracket flex.  Calliper mounting brackets are designed to stop the calliper rotating, they don't need to be designed heavy duty to stop the calliper moving in and out.  Whatever it is is not the major cause of poor pedal feel, the outer pistons are moving towards the disc rotor the same amount as the inner pistons are moving away from the disc rotor.  Hence no change in fluid usage, what extra fluid is needed to move the outer pistons is recovered from the inner pistons. For a calliper to move as a whole by far the most common reason is the rotor is not perfectly centred in the calliper.  The first thing I check is that hub face is perfectly clean, bare metal, where the rotor hats contacts it.  Then I check the that rotor is firmly held in place by at least 3 wheel nuts (or equivalent). If all of the above are confirmed to be in perfect alignment then I would check the piston sizes and ensure that the 3 inner pistons and 3 outer pistons have matching diameters (eg; 28/32/36mm).  I have seen a no name 4 spot calliper that had 1 of the 4 pistons a different diameter. Maybe I missed it, are both the callipers exhibiting the same problem? I would remove the transfer pipe and inspect it to make sure that there are no restrictions. Maybe you already have but if not I would return them with the video and have them confirm all of the above.   Hope that helps Cheers Gary
    • If you have the original log book and it didn't have a chassis number quoted, then no money required.  I have "rechassied" a number of race cars, no problem as long as you have the original log book.   Cheers Gary
    • Well the good news is that it won't run any worse with an atmo bov than it does with no bov, I've owned a few Nissans over the years (r32, s15 and now r33), the stalling issue caused by a bov or no bov while still having an afm is easy enough to live with, most people get used to driving them and just feathering the throttle when you come to a stop to avoid it stalling. Changing to a proper ecu with a map sensor is ideal but in the short term I'd just slap in the bov if you really want the whoosh sound. I looked into the pass through type maf like the R35 one above but decided against it as the amount of oil and crap flowing through the hot side would mean you'd have to clean it often to keep it working.
