Well after the happenings of the weekend i was worried about being out and about today. Hardly an import on the roads and hardly any cops either. Im guessing maybe having a sedan is a bit of a blessing, but thinking a daily might be a wise choice
I'm still driving the Stagea around. But I am considering a daily. Not due to the weekend's events, but just to have a cheaper runabout. Possibly a twin cab ute so I can use it for the run around for the house extension. :D
I posted this in another thread and thought i should pop it in here as well. It happend on Friday night.
Also spotted me getting chased down by the popo last night and getting pulled over. They had a report of a car like mine excessively speeding somewhere, so when i dove past them parked on the side of south road they gave chase. They asked if i was the one speeding and i said no. Checked my licence, rego, etc etc, but didn't bother looking under the bonnet and didn't say anything about the half cage and semi's on the rear. :D
  Rocky88 said:
got defected last night again on port road... cop was a cock as uisually... he said that next time i get defected i wont be able to renew my registration (yea right)... and that I'll lose my license (wtf)... and yea, apparently i have aftermarket brake cylinder lol :ph34r:  ... i just stayed quiet all the time and said 'have a good night officer' at the end lol
oh and yea, i tested positive for meth twice lol... then 3rd time it tested negative
lol i tested positive for weed once. those tests are acurate as f**k lol
Also spotted me getting chased down by the popo last night and getting pulled over. They had a report of a car like mine excessively speeding somewhere, so when i dove past them parked on the side of south road they gave chase. They asked if i was the one speeding and i said no. Checked my licence, rego, etc etc, but didn't bother looking under the bonnet and didn't say anything about the half cage and semi's on the rear. :down:
Damn lucky there Chad
ive been tested about 7 times now (the joys of working night shifts in town...), not a single one has been accurate.
  Krishy said:
stop smoking that shit Stewy :down:
i thought he was on something. keeps comin out to praccy day with boat in toe. like WTF :bunny:
next time were gunna have to put the sails up for ya lil fella.
Edited by sneaky1
I dunno what it is, but whenever I get pulled over they bretho me but never test me for weed... what are they trying to say, that I look like an alcoholic?
Yeah OK fair point :|
-D
just though id add this to the stupid things to be defected for; today went to regency because i was defected for wide wheels, too low and a steering wheel. Ended up coming out with a defect for a missing brake line clip in the engine bay, a rubber gromet missing around some wiring in my engine bay, and apparently my exhaust was too loud.
Just to add, my car had a full tier3 and roadworthy inspection done less than 6 months ago, where none of these issues were picked up. And my exhaust read 86db, whereas now he said it was 96 :ermm::D
regency inspectors are awesome :P
Yeah, I think the Regency inspectors are becoming hard asses. Mate took his skyline in. Got defected for something. Then got that fixed and they did him for to loud. He returned 2 more times, each time they were failing him for single items one of which was the passenger seatbelt was twisted.
is was my understanding that once you got 'the list' they couldn't keep adding to it
+1
Once the initial raping has been carried out; If you have a list the next time you go there they will only check whats on the list.
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
