What are you talking about then if not shagged street tyres that have gone bald? We clearly aren't talking about racing slicks.
A bald street tyre will perform worse in ALL situations compared to when it was new, there is not one circumstance where it would give more grip.
A racing slick is _completely_ different to a slicked road tyre.
+1
Motorcycle racing is a different kettle of fish, but the same principles apply. I have race tyres with tread (GP rated) which I will throw away after a practice session and a race ... purely because they've "gone off" and lose their grip even with tread left. When I ran slicks (for Supersport) it was the same story. But my road bikes get 6,000kms out of their rubber instead of a few hundred kms. Different environments call for different tyre treads, compounds and profiles.
Scrutineers at a race track will not permit you on track with tyres with low tread/worn rubber ... because the best your tyre will perform is between new to about a few hundred kms old. I've been behind a racer on worn tyres and been covered in bits of rubber, because he had no idea his tyre was disintergrating itself, even in a straight line, at speeds above 160 kph. He crashed later that day.
Slicks are purely bred and manufactured for high grip in race conditions ... does not mean a "bald" street tyre performs the same.
Race motorbikes, then you'll learn how vital tyres are and the differences between brands, treads, compounds, profiles, tyre pressures etc. I take the rubber on my cars as serious as the rubber on my bikes.
+1
what about the 'other' rubber, brother?
-D
Front wheel arch liners, do they have to be there?
One of mine is cut in half and the other is removed. Am I likely to be failed on this? I have no idea where I would get replacements from if so. All the wiring is out of the way and proper shielded so really all they are stopping is mud getting on the inside of the guard.
Edited by Rolls
you can get rory thompson to engineer a lock bar if you need to tho
-D
+1
Rory did a few of my 1600s and my supercharged SR20DE 200B. He can get anything thru. :(
I would pay someone $150 to save me having to change all that shit, hell I'd pay someone to change it all back more than $150.
All he is going to do is look at it on a hoist and verify that it is done properly so you might get away with even less than $150.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
