Yes but lightening can jump from a cloud to the ground so Im sure it can jump from a car to the ground. However lightening takes the path of least resistance, the metal in your car has far less resistance than your body so you wouldn't have any current travel though you. Once again the chassis is ground in your car so even if something shorted to the chassis it would just flatten your battery, you couldn't receive a shock from it.
well i dont know all the details, but i wouldnt want to be the one finding out just in case hahaha.
its what i was told at regency when it first went through with same problem, so had to get it stitched up.
Trust me what I said is what happens. There's no way that an exposed seat rail could pose an electrical hazard, even if it got wired to the ignition coil it would short to the ground pin and never be live.
If you get struck by lightening whether it decides to go via you or via the doors is really all that is going to decide if you die or not, whether the seat is exposed won't make a difference.
Hey guys, about to do some work to my car and im wondering if what im about to do is going to cause me much issues.... i know the car does regardless and the 2 times ive been pulld over they go straight to the turbo and start looking in my passanger seat/door trim for things.. im guessing a boost controller...
Anyways if yas can just make some suggestions or if you think i will be fairly good with what im going to do let me know (peace of mind :P ), from what i can tell i should be ok.
Also whats the deal if i have to goto the epa or something? can my tuner tune the engine to run fine or is it just a matter of put the stock parts back on :S?
im new to the skyline/performance scene so yeah any help is appreciated. thanks!
also im in melb vic.
R34 GT-T 1998 White.. Manual Coupe - Daily to and from work driver/Weekend cruiser.
Currently: Stock as a rock (side skirts/Turbo timer)
Pulled over: Twice... car was checked over thoroughly both times... number plate noted the first time.
About to put in:
Bosch 040 Fuel pump
Sports Panel Filter
Turbosmart boost tee bleeder (will ask installer to hide it best as can)
Stealth FMIC cooler kit (contact has provided the cooler as he suggests is best for my car and is completely legal/no cutting etc)
Splitfire Coilpacks
Dump/Higher flow cat/Custom made twin rear with large twin stainless tip - High ride to give it the best stock look.
General service with platnum spark plugs
Nistune Chip
Exedy HD Clutch
Edited by Adriantc
noo they are totaly muffd!
Stutters under boost
Engine light / slip light / diff light - Come on and the car goes shutter (mainly when its been raining)
Everything points to coil packs, so i figured id get them done with the gear.
Thanks for the tip tho ;)
got defected for fog lights.... sigh... $143 dollars down the drain. Might be off topic but i remember reading this post about some scottish cop defecting a bunch of people. I got pulled over 2 days ago when i just got my car and guess who it was zzzz was going down greenhill road about 4pm. like 3 hours after getting my car haha...
R34 GT-T 1998 White.. Manual Coupe - Daily to and from work driver/Weekend cruiser. round lights? theres your problem
About to put in:
Bosch 040 Fuel pump will be fine
Sports Panel Filter fine
Turbosmart boost tee bleeder (will ask installer to hide it best as can) not fine, unless its invisible
Stealth FMIC cooler kit (contact has provided the cooler as he suggests is best for my car and is completely legal/no cutting etc) yep as long as you dont cut/bend/mod anything structural
Splitfire Coilpacks fine
Dump/Higher flow cat/Custom made twin rear with large twin stainless tip - High ride to give it the best stock look. fine as long as its quiet enough
Nistune Chip cant comment on the piggyback, but regency will check your ecu
Exedy HD Clutch
you sound like your on the right track ;)
Did you actually get a DEFECT for fog lights or just copped a fine for having fog lights on?
Yeah, i told my tuner it needs to look as stock as possible, and hes done the hard yards finding a exhaust/cooler etc but did say the boost tee will give me troubles if they find it... so he said he will ask his mechanic to hide it and paint it black ;) so hopefully they wont find it :<
Whats the deal with the cops looking in the passanger door for 10 mins pulling out your door trim etc when they pull you over :S!
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
