i was having a look at my dyno from crd today and noticed that my a/f ratio sits at 12.5 and at the last box it dips to 12 ,now is this to lean or is it ok,
the engine has forged pistons ,rods,race bearings apr head studs.
now ive read that it could be unsafe in a stock engine so how about a forged one??
if i run 102 race fuel at the drags will this keep it safer ?
knock is at 16-25 and if i hit the limiter a 65 will come up.
your opinions would be nice if there is someone in the know about a/F ratios and knows rb engines really well it would be nice to hear from them.
thanks .
https://www.sau.com.au/forums/topic/246930-af-ratio/
i forgot to mention that i also was told that when the bonnet is down and on the street that the air flow meter and power fc will make it a bit richer is this true.
that depends on your intake setup....
if you want our opinions on your tune, take a photo/scan the printout and put it up here. 12.5 might be a tad on the lean side depending on the boost/RPM that its at.. 12-12.2 is ideal for WOT on boost.
https://www.sau.com.au/forums/topic/246930-af-ratio/#findComment-4291833
looks a little on the lean side to me... like the above posters said, the scaling on the AFR y-axis makes it hard to see fluctuations and pin point exact AFR's, but it looks like 12.5 dropping to 12 just on redline.....
I think 12 - 12.2 dropping to 11.8-12 by redline is a little safer.. I'd want to know how hot your exhaust temps were getting (this can be used as an indication to what your cylinder tempreature is).
Keep in mind, if you do get them to richen it up a bit, you will lose a bit of power. (maybe 20-30kw ??). In the end, you need to trust your tuner and as far as I know, CRD have a pretty good reputation. Perhaps talk to them a bit about your AFR's and explain what your needs are and see what they have to say. If its for a street-only car, then those AFR's are probably fine as its rare that you do more than the occaisional squirt of WOT.
https://www.sau.com.au/forums/topic/246930-af-ratio/#findComment-4294018
thanks.
as for temps
oil sits at about 70-80 de
water sits at 68-72
and i run the car at the drags with 102 octan
at the end of a run temp is oil 85 water 73
https://www.sau.com.au/forums/topic/246930-af-ratio/#findComment-4294323
yea, those are all fine. I was referring to exhaust gas tempreature - it can be used as an indication of how hot your pistons are getting. the higher octane fuel will give you a bit of overhead as far as timing goes, but as long as the tune isn't knocking, that wont be a problem. If your afr's are too lean, you could melt a piston...
gotta talk to your tuner bro - its important to trust what they have done, or if your not happy with it, discuss it with them further. If your own research disagrees with what your tuner is saying, then i guess you need to find a new tuner. No point in second guessing them...
https://www.sau.com.au/forums/topic/246930-af-ratio/#findComment-4294639
Why oh why do croyden use that afr scaling???
yeah it fking pisses me off. and means you cannot see any changes in AFR unless you get out a microscope. I have no idea what or why they have to hide but it's pretty bad form in my view. and probably not needed either as they certainly have a good reputation for tuning.
https://www.sau.com.au/forums/topic/246930-af-ratio/#findComment-4297070
some times it is impossible to flaten curve to perfection, using that scale makes it internet forum friendly :) safe from know it alls who whould bag a perfectley good tune, but couldnt tune themselves.
i agree it sucks but it probably saves them plenty of headaches.
https://www.sau.com.au/forums/topic/246930-af-ratio/#findComment-4297084
But AFR's dont ever need to be a flat line.
Its the other line that you need the nice smoothness on when drilled down into it
kinda my point, people expect flat lines under power. they should look more like an inverse power curve to some degree.
https://www.sau.com.au/forums/topic/246930-af-ratio/#findComment-4298320
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for ?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for  >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate modern almost all cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
    • Let's be wary though, if cranking is so far off, what else isn't set right? Are the dead times set right, voltage compensation etc?   It definitely sounds like it's cranking fuel issues, and holding flat to the floor is shutting them down, but I'm with Duncan that if nothing was changed in the ECU at all, and then this started, I'd be more thinking a leaking injector.   Do as Duncan said, drop the oil and make sure it's not full of fuel.
    • It actually means give it less throttle.
    • Yeah if the goal is to drive something then modifying a car is a bad idea.
    • Wowee! She looks like a major handful out there Pete!
