  • Replies 69
Just spoke to my engine builder about another matter and mentioned your situation. Whether or not detonation/lean mixtures caused the problem, for your engine builder to claim that they did there needs to be clear and irrefutable evidence of same.
If there isn't any evidence of this then it's a cop-out and they're full of shit. If there is evidence of it then you haven't got a leg to stand on.
Isn't he your dentist?
Harris do a lot of RB30's and they're close to you Joe. Worth a call. Although keep in mind they dont like to stay on the phone for long cause they're always busy
Thanks Steve, if the engineer returns with results in my favour then i'll give them a call.
As far as he has told me, he doesnt have an actual report. He says that he's had 2 guys look at it, an engineer (i think) and someone from the NRMA and both said it was caused by detonation whereas the engineer that will provide me with a report said that detonation would not cause the main bearings to go, it would cause the big end bearings to go if anything.
Yep. That's what I would've thought. But here's the thing, dude. It doesn't matter what's caused it, if it has detonated its ring out then there's sweet f**k all you can do.
he said the pistons and rings are fine as well as the bores so i highly doubt it was detonation. the only part in the entire motor that failed were 2 of the main bearings.
Engineer will have a report ready for me by wednesday i hope. i'll ring him today and see if he'll go earlier. no point in speculating if we dont know 100% what happened.
Edited by SECURITY
  • 3 weeks later...
I'm sure Joe will give an update sooner or later, but I understand the engineer confirmed there was nothing wrong with the build, the issue was un-related.
It would be good to see the details posted since the reason I heard was unusual and an interesting warning about how small things can build up to a dead motor
Engineer report in:
results are:
bearing failure caused by overfueling/incomplete combustion + a restriction in the oil pickup which caused low oil flow at high RPM. the over fueling + the oil pickup restriction caused the motor to fail.
I'll post up the engineer report once ive edited out my details etc.
who tuned the new engine? As from what im reading there it has had problems since it was installed as the 8000klms travelled on an overfueled engine. This is critical on initial run-in as an excessively fueled engine will not allow rings to bed-in and the overfueled combustion chamber to release fuel mixture into sump area on compression stroke.
Edited by DiRTgarage
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
