  • Replies 69
Just spoke to my engine builder about another matter and mentioned your situation. Whether or not detonation/lean mixtures caused the problem, for your engine builder to claim that they did there needs to be clear and irrefutable evidence of same.
If there isn't any evidence of this then it's a cop-out and they're full of shit. If there is evidence of it then you haven't got a leg to stand on.
Isn't he your dentist?
Harris do a lot of RB30's and they're close to you Joe. Worth a call. Although keep in mind they dont like to stay on the phone for long cause they're always busy
Thanks Steve, if the engineer returns with results in my favour then i'll give them a call.
As far as he has told me, he doesnt have an actual report. He says that he's had 2 guys look at it, an engineer (i think) and someone from the NRMA and both said it was caused by detonation whereas the engineer that will provide me with a report said that detonation would not cause the main bearings to go, it would cause the big end bearings to go if anything.
Yep. That's what I would've thought. But here's the thing, dude. It doesn't matter what's caused it, if it has detonated its ring out then there's sweet f**k all you can do.
he said the pistons and rings are fine as well as the bores so i highly doubt it was detonation. the only part in the entire motor that failed were 2 of the main bearings.
Engineer will have a report ready for me by wednesday i hope. i'll ring him today and see if he'll go earlier. no point in speculating if we dont know 100% what happened.
Edited by SECURITY
  • 3 weeks later...
I'm sure Joe will give an update sooner or later, but I understand the engineer confirmed there was nothing wrong with the build, the issue was un-related.
It would be good to see the details posted since the reason I heard was unusual and an interesting warning about how small things can build up to a dead motor
Engineer report in:
results are:
bearing failure caused by overfueling/incomplete combustion + a restriction in the oil pickup which caused low oil flow at high RPM. the over fueling + the oil pickup restriction caused the motor to fail.
I'll post up the engineer report once ive edited out my details etc.
who tuned the new engine? As from what im reading there it has had problems since it was installed as the 8000klms travelled on an overfueled engine. This is critical on initial run-in as an excessively fueled engine will not allow rings to bed-in and the overfueled combustion chamber to release fuel mixture into sump area on compression stroke.
Edited by DiRTgarage
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
