  • Replies 45
265 on an 8inch wheel? Overkill bad. + wouldn't look too nice as the tire would stick further than the rim. Im running 245/40/r18 and they sit perfectly on my 9.5 inch wide rim.
You have gone to the other extreme, as those are too undersized for a 9.5" rim
i got 265/30s on my 19x8s and they sit pretty much dead on in line with the rim maybe the smallest of measurements inside the rim, i got a pic that sorta shows it the best but cbf making it smaller and uploading
Edited by 2BNVS
i had a set of 7.5"wide BBS wheels which had a total physical width of 8.12inches.
i highly doubt this variance will be consistant throughout brands. some may be accurate, depending on the shape of the wheel.
i'd assume this variance similarly carries through to tyres.
food for thought.
ROTF!!!! LMFAO!!!! WHAT A PISSER OF AN AVITAR!!!!! hAHAHAHAHAHAH!
9.5 * 25.4 = 241.3
He's 4mm under, how is that too undersized?
Perhaps a 255 would look best, but I don't think 245 is too small.
Just going off a tyre chart i have seen. A 245 tyre is best suited to a rim with a width of 8" to 9".
well i ended up getting 265 on an 8 inch rim
You are kidding right? Why on earth would you do such a thing? It would look extremely gay and isn't doing you any favours for traction. Using a good quality 225 tyre ( Toyo R1R, T1R, etc) will give way better traction than a cheapo 265 tyre. What rear camber are you running? Unless you've got adjustable aftermarket rear camber arms installed you are no where near the ideal alignment settings for optimal traction and tyre wear.
Install some pineapples set to traction also.
Pfffffttt @ undersized. I know loads of people who are running 215's on 9.5" rim with no problems at all
^^^ Not as gay as that orange Tempe Tyres spec abortion in your avatar...
265 is way too big for an 8" rim, imagine the side wall flex when cornering hard!
^^^ 215 on a 17x9.5 front, 215 on 17x10 rear. You still think it looks gay?
Edited by ~Hypnotik~
I think that comment was unnecesary. :thumbsup:
The fact of the matter is that there are sizes in each brand that have recommended rim width fitments, each brand's recommendations vary as there are a huge amount of different casing, sidewall and tread constructions in the industry.
Most manufacturers do not recommend fitting a 265 wide tyre to an 8" rim as it may be too wide and you can risk sidewall and bead damage from the extra stress of stretching the wall too far inwards.
Almost all manufacturers also do not recommend fitting 215 wide tyres on to a 9" rim as it is too narrow, can damage the sidewall and you risk pulling the tyre off the rim when it is under load (cornering).
I'm not sure when the suspension, braking and tyres section became part of NissanSivlia.com instead of SAU....
So, it's simple. Any further attacks on someone, their opion, or their car in this thread will result in warnings or bannings.
Also, every tyre manufacturer specifies the safe rims sizes for their tyre widths and there are variances between brands. Some people choose to ignore those recommendations and go under or oversize, if you do so it is illegal and potentially unsafe. Its that simple.
You dont know much then do you. They sit perfectly with practically 0 stretch. And if you knew anything 245/40 in one brand WILL be a different size in 245/40 in another brand :thumbsup:
You dont know much then do you. They sit perfectly with practically 0 stretch. And if you knew anything 245/40 in one brand WILL be a different size in 245/40 in another brand :)
Are you really that petty and mentally insecure that you need to try and insult someone even after they have explained where the information came from and even after others have also backed my statement.
Others have also stated that rim width recommendations will vary, depending on tyre manufacturer, so we may both be right.
Grow up little fella, you have a lot of information to learn, to know what i know. :thumbsup:
Before i knew any better, this is how a 275 tyre fitted on my 19x8" rim. I did all sorts or motorkahna, drift and motorsports events with these tyres and never had an issue, that is not to say that i recommend using such a wide tyre on a narrow rim. I now have 245 at the rear and will be going 235 all round once i need to change the rear tyres.
Yea 275 looks shit on a 8 inch wide rim (like you just proved by your picture), even tho u have such a low profile u can still see that the tyre sticks out further than the rim itself.
Looks like your the one that took what i said more to heart and had a little cry about it :) Its ok "big fella."
Judging by my picutre, do you still think that 245 on a 9.5 inch rim is too small?
Are you really that petty and mentally insecure...
Grow up little fella, you have a lot of information to learn, to know what i know. :)
Judging by how personal this debate is getting I would say that its about time this thread was closed. :P
    • PULSAR PSR2860R 0.86A/R or 0.64 GEN 2 Turbocharger Both are -50*67mm 8 blade billet compressor wheel Cheers
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe.....EDIT... nope, the Kraken is a cast jobbie, the REv9 uses welded up stainless, plus $8000 AUD before shipping, installation and tuning) Where else in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit that Pulse fitted, and it was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
