Hi ive been having this issue for a month know i did all the normal stuff like new fuel pump, coils, new crank angle sensor, afm so on but hasnt solved my problem if any one has any idea on what to do next please let me know as i can not drive the car its really annoying. :)
https://www.sau.com.au/forums/topic/247206-r33-dying-randomly-while-driving/
You can do an ECU diagnostic using a paper clip and shorting out two pins on the consult port, a code will flash on the dash. Do a search for it on the forums, the ECU will supposedly remember problems for 50 or so starts. May help shed some light...
Edited by MintR33
  SexyPete said:
Does the car idle roughly or abnormally?
i got that problem fixed it did idle rough got a new crank angle sensor and went away just dyes randomly know say ur driving and out of no where will loose all power and stop
does it idle when you slow down, after applying a tiny amount of boost. i've been having this problem as well. we figured out that the car stalls when you apply boost, even if its a little bit and then you come to a stop or change gears. i think its sumthing to do with the turbo , but then again i mite be wrong
i hope its not the turbo cars gonna send me broke lol :)
I would say it's an electrical problem, possibly one of the relays controlling the injectors or coilpacks. Maybe check the plugs (onto the relays) first, then try replacing the relays.
Sounds like your ignitor if its a series one (being that year it should be) which is located in the engine bay, S2 is actually bundled in with the ECU inside the car to avoid this problem. As it warms up (and its on its way out it) it should cut power to the coilpacks. Once its cooled (or using a cool shorting trick) it should start again. Replace or reposition it away from the engine to fix. Common on RB30's with the ignition module under the dizzy
Hey mate, I just collected my car from the workshop. I was having the same problem as you. I just did my 100k service..the mechanics told me the timing of my car was abit off which was causing the dying of the car and i had a boost controller installed which tuned my turbo. My car is driving fine now.. maybe you should check the timing.
Cheers!
Cheers!
Thanks man ye i got all that checked all turned out good engine runs like a dream my tuner is saying it can be your alarm kicking in when you are driving which imobilises the engine and shuts offf all i gotta say
SKYLINE OWNER SHIP= STRESS and ALOT OF FUN
