R33 Dying Randomly While Driving
sxwpn
 Share
Hi ive been having this issue for a month know i did all the normal stuff like new fuel pump, coils, new crank angle sensor, afm so on but hasnt solved my problem if any one has any idea on what to do next please let me know as i can not drive the car its really annoying. :)
You can do an ECU diagnostic using a paper clip and shorting out two pins on the consult port, a code will flash on the dash. Do a search for it on the forums, the ECU will supposedly remember problems for 50 or so starts. May help shed some light...
Edited by MintR33
Does the car idle roughly or abnormally?
i got that problem fixed it did idle rough got a new crank angle sensor and went away just dyes randomly know say ur driving and out of no where will loose all power and stop
does it idle when you slow down, after applying a tiny amount of boost. i've been having this problem as well. we figured out that the car stalls when you apply boost, even if its a little bit and then you come to a stop or change gears. i think its sumthing to do with the turbo , but then again i mite be wrong
i hope its not the turbo cars gonna send me broke lol :)
I would say it's an electrical problem, possibly one of the relays controlling the injectors or coilpacks. Maybe check the plugs (onto the relays) first, then try replacing the relays.
Sounds like your ignitor if its a series one (being that year it should be) which is located in the engine bay, S2 is actually bundled in with the ECU inside the car to avoid this problem. As it warms up (and its on its way out it) it should cut power to the coilpacks. Once its cooled (or using a cool shorting trick) it should start again. Replace or reposition it away from the engine to fix. Common on RB30's with the ignition module under the dizzy
Hey mate, I just collected my car from the workshop. I was having the same problem as you. I just did my 100k service..the mechanics told me the timing of my car was abit off which was causing the dying of the car and i had a boost controller installed which tuned my turbo. My car is driving fine now.. maybe you should check the timing.
Cheers!
Cheers!
Thanks man ye i got all that checked all turned out good engine runs like a dream my tuner is saying it can be your alarm kicking in when you are driving which imobilises the engine and shuts offf all i gotta say
SKYLINE OWNER SHIP= STRESS and ALOT OF FUN
 Share
    • Sadly, it won't happen. The AC controls in our cars are essentially on-off. Whereas the AC in new stuff is more a case of variable displacement compressors giving infinitely variable output.
    • I don't think anyone did. But it still made me consider. For me personally it wasn't clear whether the AC experience in my car was shit because it is an old system, or because it wasn't maintained. Looks like it may have just been the latter. I see some more modern setup being sold as an upgrade and I wonder whether it would make it drive like AC in a modern car. Where you don't really hear it or notice it. But maybe that's asking for too much as well.   Haha, stick it in a Nissan Cube and you end up with a driveable fridge I'm not doubting your experience. Just thought it was interesting to hear the AC technician's thoughts on it.
    • Guess I should be hunting down one of these big ol ford units then for max flow ....  I've had fresh gas in mine and it was never as cold as it is now . The compressor could have been trash though, like I said I am one example with a bunch of unknowns.
    • I don't know if anyone was seriously suggesting a retrofit of an Echo compressor in place of a more-or-less working original comp. You'd have to change the hoses at the bare minimum to do so, and that will definitely add significant cost. I had to get my hoses modded when I did the engine transplant and chose to use the Neo's AC over the even older R32 comp. That was startlingly more expensive than expected for what looks like a simple welding job, and a massive pain in the arse when it turned to have a pinhole leak in the weld too. The Frenchie's kit is for people who have next to nothing of the original system or have more than that but some of it is a bit shit and better off thrown away than salvaged. If you've got 90% of the system, you just patch it up. Mine is currently degassed because it apparently has a big leak somewhere. If I find it is the compressor, I will be looking to take my spare comp to a shop to assess and/or recondition, rather than contemplating a retrofit to anything off-brand.
    • I went and got the aircon regassed in the Stagea today and asked the guy about the upgrade to the Toyota Echo compressor. He was saying it is likely not going to be as good. It is newer but smaller and not going to pump as strongly. And it would be better to try and get a new OEM compressor. He was saying that the improvements people are seeing may be more likely due to regassing the system. I thought it was interesting to hear. Going by the sticker the system in my car was last checked in 2015. Gas was at 50% which is apparently beyond terrible. Under 80% is where efficiency already falls apart. Anyways, with fresh gas the AC is now bloody freezing. I think it may be working a bit less hard as well. I need to drive it a bit more to try it properly. Previously on hill starts it would utterly bog down the car. I'm hoping this is a bit better now. The frenchies kit looks great, but $1400 for the compressor upgrade alone makes it a bit of commitment. Very much so compared to a $150 regas.
