Is it true that tuners, on a turbocharged car will advanced the timing until they get a reasonable knock level.
i was told that on N/A car this method can't be applied because on a N/A car will reach torque drop off before high knock level and on turbo cars you reach a a high knock level before you reach torque drop off.
this is a ignition map for my rb25det can anyone give me any kind of suggestions for improvements. this was increased +2 deg.
from the stock Power FC ignition map.
thanks guy's
https://www.sau.com.au/forums/topic/247224-basic-engine-ignition-timing/
Any mods etc done to it?
Heres the ignition map of a stock rb25, by no means follow this as it could cause damage to your engine as the fueling will be totaly different!
Edited by murrayis
mods include
Intake with 100mm throttle body
Full 3 inch 5 zigen exhaust.
FMIC
Hks SSQBOV
Gt35r turbo with 6 boost top mount
Tial 44mm external gate
Sard 280l/h pump
Sard 800cc injectors
Sard fuel regulators
Hks twin power
Z32 AFM
Sard fuel rail
Buildt motor
Lm2 wideband
Powerfc and datalogit
(just of the top off my head.)
I've added a list of logs to be looked at
I'm running 12psi and can fell the tire wanting to rip loose in thr. gear.
any help would be very much appreciated. there is a pic of the set up in the attachment.
this car is for drag porpoises
thanks again guys.
Edited by MJTru
i have a race on the weekend and any help would be very helpful looking at the AFR i will try to datalog and get a AFR of 12.0 at WOT.
I'm learning about timing and need a little help on the topic.
thanks for all your help again guy's this car would not be where it is today if not for SAU guru's
get a 3g mobile phone, and for $300.00 USD$ i will tune it for you.
the 1st map has way too much timing in it for aussie pump fuel....the second one posted is more like it
the fist map is my whole ignition map that is in settings 2 on the datalogit screen i Had add +2 deg timing to the stock map.
this is the whole map was raised by +2deg. timing
the second map was a log in 4th gear at WOT.
and the resulting data.
i use crappy 93 octane fuel ( this is not good but with a knock of no more that 15 at WOT is not to bad )
what do you guy's think.
i though that tuner keep on adding timing until they reach torque drop off or high knock levels.
Guilt-Toy how can you tune it using a Phone ????????
how about i just buy you a all payed trip to my shop ( a vaction to this place)
hotel and everything payed in full. lol what you say.??????
that can happen... where are you ?
look at my remote controll thread in my sig
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
