RB30:
- Full set of Federal and Mogul cast pistons only, no rings - better than stock rb30e pistons.
to fit standard bore size - use standard rb30e piston rings.
$200
- Standard Rods + Pistons + Rings in good condition.
$50
RB25:
- Air con compressor
$150
- Short block - has pistons, crank and GTR rods bolted on only - good for rebuild:
$300
RB26:
- Standard pistons, came off R32 GTR with 89,000km - good condition
$100
R33 GTST:
- Custom turboback exhaust with changeable diff-back section to stock - mild steel - 2yrs old
$250
RANDOM:
5x 14x8 + 1x 14x9 wheels (i think) - bought these and they didnt fit on my skyline.
$200
Autogauge gauges - water temp, oil temp + oil pressure in bracket to fit into DIN pocket.
comes with all senders and sandwich plates needed - used
$80
I'll update the thread when i find more stuff in my garage.
Contact via PM.
https://www.sau.com.au/forums/topic/247292-rb30rb25rb26r33-gtst-parts/
wouldnt happen to have some rb pickups u want to offload?
I'll check my garage but i doubt it mate.
all pm's replied.
guys, im a bit slack in getting pics up because of work bla bla...
the gauges are the smoke faced gauges from just jap that are black when they're off and light up when you turn the ignition on.
UPDATE: found a boost controller to go with the kit - i will sell the entire kit for $100 with the 4 gauges + oil pressure plate/switch. i couldnt find the water or oil temp sensors anywhere. they go for around $30 for the water temp adapter from justjap and around $5-10 ea for the temp sensors.
pics up.
Note: stock rims in pic do not come with this set.
post-13452-1229316100_thumb.jpg post-13452-1229316108_thumb.jpg post-13452-1229316130_thumb.jpg post-13452-1229316153_thumb.jpg post-13452-1229316164_thumb.jpg post-13452-1229316178_thumb.jpg post-13452-1229316200_thumb.jpg
Edited by SECURITY
Where are you located? I need an air con commpressor.
im in bankstown. pm sent.
Can you tell the reason why those wheels didn't fit your car?
they dont clear my brakes. with spacers i think they'll fit, they are a skyline stud pattern though.
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
