I ordered one of these systems for my R33.Actually arrived with conventional stainless steel bell mouth dump pipe!WTF? Went ahead and installed the whole thing anyway as there are mixed reports about split dumps and i couldnt be happier.The cat they sent was a x-force hi-flow as well.Good power gains and an awesome exhaust note!
Its a shame.. why did you ask if you had ordered it already?
I would totally stay away from the split dump pipe. They are horrible. Mine gave me nothing but issues boost wise, even after grinding it out for the wastegate to clear it still over boosted.
GL tho, i hope you dont have the same problem! (and GL installing it ;) they are tricky!)
Hi Mike, glad I saw this one.
I am not sure why you received the Bellmouth Type Dump/Front Pipe rather than the Split Type so please accept my apologies for that.
For those concerned about the Split Type, we had an issue with the flanges used in our early batch of these however as we are constantly working to develop and improve every product we sell this issue has been corrected and all Split Dump/Front Pipes now use a larger, thicker flange.
We also guarantee the performance and quality if these and every other product we sell, so if you purchase and are unhappy for whatever reason, we want to know about it!
These systems are covered by a 12 month warranty, and currently we are shipping the Hyperflow Systems with a Catco Ceramic High Flow Cat instead of X-Force so they really are great value for money.
Thanks for the support guys.
Regards,
Steve Thatcher
Director
Just Jap Racing
GL tho, i hope you dont have the same problem! (and GL installing it :D they are tricky!)
i hadnt, it just took 2 days for someone to reply. and by that time i did. i will let all you guys know how it goes anyway
    • Only reason I started replacing hoses was I went for a short drive to the shop the other day and finished shopping and started the car and started to drive off and could see a big trail of fuel in the rear view mirror. Parked up and found the bottom hose to the fuel filter had busted. Lucky I was near a car part store and was able to get a replacement hose and back on the road. But got me thinking I had owned that car for around 20 years and was all original fuel hoses so probably time to replace all of the fuel hoses. Was pretty lucky it went where it did.
    • A few kg falling from a few feet is enough to move parts of your skull inwards into your brain Also, there's always news about people getting crushed, and occasionally killed, working under cars Be safe is your endeavours
    • I was just going to replace the fuel line and keep the stock one, but they do look pretty nice lol.
    • Are you going to delete the stock damper or are you just replacing the fuel lines and keeping the stock damper?  There are also options for sexy ones if the stock one is too ugly for you lol -  https://www.radiumauto.com/Fuel-Pulse-Damper-Inline-Kits-P751.aspx or https://www.radiumauto.com/Fuel-Pulse-Damper-Direct-Mount-Kits-P759.aspx So sexy.
    • I think you guys are right. The only reason I thought it was a restrictor was I had seen the same yellow band on the r32 boost restrictor. Will just replace with a standard fuel hose. Thank you for your speedy replies. I'm sure I'll have many other silly questions.
