hey guys, this JUST happenned today when i was driving back home from work. the car felt really heavy, ruff, when in gear. also noticed that the oil pressure bar was just one bar away from 8kg/cm3. i never really take not of the oil pressure, but i do know that the ideal 4kg/cm3. is that correct. is this a potential problem? any ideas whats goin on?
https://www.sau.com.au/forums/topic/247305-oil-pressure/
Not sure, but I'd say a big end is on the way out, you have an oil blockage, probably at the big end journals, your motor is in dire need of a rebuild. If you keep driving it you will kill it big time.
But I'd get a second opinion, bl##dy hard to diagnose over the web........
https://www.sau.com.au/forums/topic/247305-oil-pressure/#findComment-4294842
yikes, how much would a rebuild cost btw??
https://www.sau.com.au/forums/topic/247305-oil-pressure/#findComment-4295303
If it was cold and when you first started it up, c'mon, oil pressure will go to 8 and your car will be a bit rough until it warms up. If its happening when its warm, thats a different story.
thats what i thought at first.. but the oil pressure keeps going up to the marking below 8 even when the engine has been running for a while. goin to xspeed on friday to get it chkd out..
https://www.sau.com.au/forums/topic/247305-oil-pressure/#findComment-4296455
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
