As topic says, my RB25 r32 is up for sale.
I have owned the car for just over a year, but have to sell it as I no longer have any parking space for it, due to being set to receive a company car in early Jan.
I purchased it as a rb20 manual and since receiving it have spent over 12k in the past year, with receipts to show.
The RB20 was removed early this year and replaced with a rb25 engine and manual gearbox out of r33 front cut with 115k's on it.
This was done by ECC and the car is fully mod plated and legal.
During that time a major service was done, replacing the belts, waterpump etc, just to be on the safe side.
Since then the car has covered just over 10 000kms.
During the 10000kms, the car was a work in progress, with the following mods/parts being added;
Engine:
RB25det, 128 xxxkms on it
New engine mounts
New belts and waterpump
High flowed turbo, by Precision Turbos
CES split front/dump pipe
High flow cat
Stainless steel catback exhaust
Hybrid Front mount
Apexi Pod
Splitfire Coils
Turbosmart plumback blow off valve
Walbro high flow fuel pump
Malpassi fuel pressure regulator
Computer
Power FC
Gizmo Intelligent Boost Controller
Drivetrain and Suspension
RB25 Gearbox
Cusco single plate clutch
ISC adjustable rear upper arms
ISC adjustable toe arms
GAB coilovers front and rear
Custom one piece 3 inch tailshaft
Hicas lock bar
Zone 17inch by 9 inch wide rims
255s on the back
235s on the front
Also, spare set of r33 standard wheels with 95% rubber
Interior
Splitfire boost and oil pressure gauge
Blitz automatic turbo timer
Cd player
JVC splits in front
Sony Xplod 6by9's in back
Kicker 10 inch sbu
2 channel amp powering JVC splits
2 channel amp powering Kicker sub
Exterior
Trust GRacer copy front bar
M spec side skirts
M spec rear pods
Overall the condition of the car is good. Mechanically it is perfect. Exterior has a few blemishes as expected of a 1990 car. The car was built to be a quick streeter with the goal of ultimately taking it down for circuit racing. Unfortunately, the budget at the moment does not allow for this, and the car has not seen the track, apart from one Willowbank outing, where it made high 13's with stereo components, full tank and myself (110kg). It was my first time down the strip and the car is easily capable of low 13's.
The power fc was installed and tuned by Brisbane Tuning and Turbo Centre and was tuned for reliability, making 219rwkw at only 12psi.
I am asking for $15 000 FIRM.
The price is firm as I can part the car out and recover more money, but do not have the patience.
No swaps please as my work car is arriving in Jan, and there is simply no room for another car at the moment. I may be interested in a swap for a roadbike plus cash.
For any questions, or to arrange an inspection, please contact me on 0408 457 698. Please note, the car will not be available to be picked up until early Jan, when I pick up my work car. Up until then it is my main mode of transport.
https://www.sau.com.au/forums/topic/247309-rb25det-r32-modified/
Hey interested buyers,
  • Went to check this car out today, definitely needs a respray, body is straight, panels in good nick.
  • Motor sounds good but possibly running rich (exhaust is jet-black) , possibly re-tune.
  • Interior is sound, but requires gearbox/handbrake boot. AC window vents good, left hand side vent looked to be on way out.
  • Needs bit of work for a RWC (rear windscreen wiper, speedo, tires etc).
  • Surprisingly stereo not installed, unsure y, due to listed in specs (did see evidence of amp in boot and parcel shelf speakers)
  • Speedo needs hooking in (navara mod) Passenger window needs attn (possibly loose connection or motor / switch) Sunroof doesnt work, possibly come off rails.
  • Owner says there is a clunk in one side of rear coilover (booked in next week)
  • All chassis / vin numbers all match up and are legit however, according to Nissan Fast its 1989. (see image for confirmation)
  • I'd say this is a great car for somone who is willing to spend the time or money to get it up to scratch, otherwise quite a nice car.
Thanks,
Good luck with sale.
Thanks,
for rwc it needs:
speedo to get hooked up - pretty straight forward. have the part number needed, and it's a $30 part
needs the rear wiper to be reattached
needs the hicas warning light to be turned off at the dash - hicas has been removed
and that's it.
the r33 tyres are in rwc condition. they are less than a month old.
will get some engine bay pics up
stereo is working, but is out. used to have a dvd player, but pulled it out. have a pioneer cd player, but haven't put it in yet.
cheers
ps. at the moment am not selling the car in parts, so won't be selling it without wheels etc, as i will have no use for the wheels once the car is sold.
if i do decide to part the car out (ie, it doesn't sell), i will part all the bits out pfc, turbo, exhaust etc etc etc to recover the cash.
  • 4 weeks later...
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
