Blimey, I may have just found the new set of wheels for my v36
Runs to library to borrow book titled: "so you're gonna perform a home operation to remove then sell your kidneys to pay for a new set of Nismo LMZ5 wheels"
Do I see front bar parking sensors... perhaps intelligent cruise control too?
whenever i see a 350z cruise down the street whether it be an 08 model or a 03 model i still eye it out.
they are a timeless design as is this 370z.
nissan have nailed it on the head again.
have to agree.. i really like the 350s and i think the 370 is a step up.. the above car does in deed look very nice
Personally, if I were Nissan I'd be hoping this is a really crap photo and it cuts up a lot prettier in the flesh. It's terrible IMO. The kit could be what's killing it. Looks like the naive design coming out of Korea 10 years ago. Terrible.
i think it looks great and reminds me alot of the older z cars. clearly what the car is based on.
the only thing i dont like about the 350z is the back lights, wtf were they smoking when they came up with that idea!?
but the 370 looks a little better. cant wait to see a real one.
looks better then an s15 imo
i think we're commenting too early. we have to see one in person pictures sometimes don't do cars any justice. i think seeing this car approaching you on the opposite side of the road would look like one mean mu'f**ka.
and i agree though some wider wheels would look good
Edited by DrewII
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
