Hi i have various gtr and gtst parts for sale
gtst head $500 ,perfect
rb26 dett block $400 perfect
rb26 pistons and rods $250
n1 pump good condition $200
water pump n1 $100 used good condition
standard gtr injectors $200 for 6
1000cc RC engineering injectors $500 brand new never used! bargain
standard r32 gtr turbos $300 the pair good condition slight shaft play.
veilside r32 gtr exhaust good condition $300
r34 gtr stainless dump pipes standard $200 the pair excellent condition
standard r32 gtr intercooler $150 fair condition no leaks
standard r34 gtr cooler $450 brand new
hks rb25det exhaust manifold hpc coated $500
standard r33gtst exhuast $200
standard r33gtst bonnet white $200
standard r33gtst rear wing $150 white
standard r32 gtr suspension $250 front and back
standard r32gtr suspension front only $150
standard r33 gtst 16 inch rims with new rubber $400
standard rb26det exhaust manifolds
rb25det valve covers $100
r32 gtr 2 way diff centre $400
nismo lmgt4 18x 9.5 +30 offset bronze rims and bridgestone re55 semi slicks $3000 firm! excellent condition no gutter rash but semi slicks down to indicator
standard r34 gtr rims with rubber $2000 firm no gutterrash.
rays early gt-c's silver 17 inch with hub adapters and rubber $500 great for drifting!
evo9 brembo calipers $500 pair excellent cond.
buyers to pay all shipping costs from adelaide.
guys please these prices are cheap so be quick and please dont haggle.
will post pics tonight!
i will only answer pm's.
i also have
6 x standard coil packs r33 gtst series 2 $250 all up
6x standard coil pack r34gtr $250 the same as above
6x standard coil r32 gtr coil pack $200
r33 rear taillights pair $400
AGAIN pm me pls
Edited by ax53b70p25
n1 pump good condition $200sold
water pump n1 $100 used good conditionsold
1000cc RC engineering injectors $500 brand new never used! bargain sold
hks rb25det exhaust manifold hpc coated $500 sold
evo9 brembo calipers $500 pair excellent cond.sold
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
