  • Replies 133
Originally posted by zanda
so to ask the question again, any other people willing to tell their tales of horsepower and woe?
...or are we saving that for pas?
Ohhhhh boy Zanda i could tell you a tale about horsepower and woe.. but thats till after PAS.... I'm sure paul can testify that my story about sly should have a movie about it..... after PAS though :-)
Paully,
Used to old turbin and squirted off a 316rwhp @ 12psi(without NOS). We tried 18psi for a couple of run but the graph was shitting and the coil packs begun to break down + (pinging).
So I can do a dyno run at PAS if needed though with the time need to setup car on dyno packs I doubt if you will even have time to get more than two cars on a run. 18psi figures were SWEET
:headshot:
Originally posted by SHUTO-BOY
JUDGED- we need NOs!! hope u run it on the dyno with Nos, comeon mate
I will see if STEVE SST will let me run on his dyno with a 2sec shot just to see some numbers but that will be after PAS as need to keep the cars we have there running and alive.
:ak47:
Originally posted by Steve-SST
This shootout may end up with a few dead cylinders.
Yeah mainly Pauls:D please tell me there not using those dyno pac dynos for auto salon!! can someone confirm or deny this for me?? those wheel changes are so bloody long and frustrating... the crowd will hate it.... dyno shootouts take long enough as is gettin eveything ready as shown in motorvation.... but to also have to take off the wheels is going to show no lack of interest to the crowd when having to wait even longer!
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
