hey all jus got a tune the other day on my r32 gtst rb20det with power fc fuel pump r33 turbo and ya other basic mods boost controller etc. was aiming to run 14 psi but had to cut back to 13 psi cos my standard injectors maxed out and made 241.6 hp atw so now got to put gtr injectors in and go retune it but want to know how to adjust the fuel mixtures on the pfc when i put the injectos in so it won't run as bad so i can drive it to the dyno. So all im askin is can i do a small adjustment on the power fc so i can get to the dyno with no problems hope that makes sense thanks
https://www.sau.com.au/forums/topic/247407-injector-question-with-power-fc/
Need to enter the injector correction and new latency into the PFC so you work it out as shown below
Old SIZE / New Size = Correction
260cc / 444cc = 58.558%
New Latency - Old Latency = Latency Correction
0.772msec - 0.89ms = -0.118
Then to enter the values you do the following
so for the first value that's displayed in % you enter/select down till you get to 58.55% then the 2nd list which show's the correction you select down again as the value is negative till you get to -0.11 ( I think it rounds it off to the closest decimal so being 0.118 you might be forced to select 0.12 - can't remember off the top of my head but you'll see when you do it)
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
