  • Replies 112
Are there a lot of imports? Not only for the drifting?
If your number plates indicate a negativity towards V8's, would it be wise to go?
There is a cubic shitload of imports at PC events and there is NONE of the attitude you get at Summernats. None!!
https://www.sau.com.au/forums/topic/247414-powercruise-17/#findComment-4298908
except when you happen to make the final of the street racing.....then disqualify you...please post vid.
https://www.sau.com.au/forums/topic/247414-powercruise-17/#findComment-4298911
That's nothing to do with the import sentiment. It just doesn't exist at this event.
And just in case someone brings up the autostyle issue, Dom was beaten fair and square by a faster car and would have been time and time again.
https://www.sau.com.au/forums/topic/247414-powercruise-17/#findComment-4298971
what about me....post the vid....post the vid.
im only coming back to P17 to get whats truely mine.
what about me being booed by the punters every time i knocked a knuckledragger out of the competition.
https://www.sau.com.au/forums/topic/247414-powercruise-17/#findComment-4298983
It wasn't just the knuckledraggers booing. But it seems you couldn't hear me behind the camera! :) :)
:D
Oh, you're gonna have to get around me to claim your trophy dude.
https://www.sau.com.au/forums/topic/247414-powercruise-17/#findComment-4299010
It wasn't just the knuckledraggers booing. But it seems you couldn't hear me behind the camera! :):)
:D
dont have to get around you as the last time we went heads up it was disgustingly one sided....lol
where's that vid?
you will have to put it on the back wheels to get me.
the smack talk has officially begun. :)
https://www.sau.com.au/forums/topic/247414-powercruise-17/#findComment-4299080
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
