Im not expacting a MASSIVE increase in power, as a final figue. As Michael said, the differences should be huge.
As there is 1.5m less of intercooler pipeing and individual throttle bodies the turbo will spool quicker, reach peak boost at a lower RPM and be alot more responsive.
More responce means I have a widerpower band, more usable torque and power at lower RPM.
Please bear in mind this is going in a fairly light R32 too, not a bulky R34.
  • 1 month later...
  • 1 month later...
The wait is finally over guys! This is it - the one of a kind RB25DET NEO with GTR plenum, NO adaptor plates!
Engine fired-up no probs, now taking it easy for a while to run-in the head and make sure there's no leaks etc. The engine asks for a tune-up.
Latest details of the mod are as follows:
- Used the standard GTR air box, AAC valve and air regulator under the plenum (for last two, harness modded with connectors to suit).
- Used the standard GTR water tube under the air box and water hoses to suit. One outlet from the water tube was plugged.
- Used the standard GTR blow-off valve setup.
- Ditched the Neo oil cooler/filter holder as it interfered with the air box and used instead a standard oil filter holder from any RB20/RB25.
- Used for now the NEO fuel rail and injectors. Will upgrade later to GTR rail and higher flow injectors.
- Used the NEO TPS (throttle position sensor) with adaptor piece as seen in the photo.
- Used the NEO boost sensor (connected to the plenum).
- Ditched the throttle motor and sensor (NEO traction control system).
- Ditched the carbon canister purge solenoid and connected the canister through one way valve to the GTR factory port.
- On the turbo side, used a Turbosmart elbow reducer 3in to 2.5in to connect the turbo outlet with the GTR air tube
More pics to come!
Edited by GTS4WD
Sweet, getting back my head this weekend so I will throw up some pics to compare and then I will be PMing for the much needed advice. Still need to replace the guides and get them reemed though :D. Sweet job nonetheless, how is the response and PM me details as I am going with an RB26DETT bottom end with the Neo head and keeping the VCT and using the RB26 covers and whatnot, may just keep it single turbo as I already got my HKS cast iron setup with external gate.
  • 4 weeks later...
Do you think there would be any problem with leaving out this bolt as my machinist forgot this and widened the water outlet for the GTR setup. Thinking about leaving it this way, your thoughts?
I think this is a bolt guide, nothing more.
Has done similar work, perhaps someone would be helpful:
http://picasaweb.google.ru/strelok.vc/2009...feat=directlink
No. It is still at the stage of assembly. Plan before the end of the month run.
At the moment, is a problem - how to control valve VCT because ECU will stand by RB20DET. I do so out of ECU, the external electronics.
There are thoughts about this?
Strelok, ya tebe otvetil na nisme.
I would certainly try to get a bolt back in there. Its not a ocating bolt, it clamps the head down to stop a coolant oil leak from those 2 passages.
Hmmmm this would require me to get the area filled and tapped for the bolt as the inside of the head in that area was ground to mate proper with the RB26 ITB water ports. Gonna ponder on this for a bit, I am think the headstuds should have more than sufficed for this but I will rethink it.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
