based on a search it appears my original question has been answered - R34GTT 6 spoke rims will fit an R33 GTST, but it would be useful for many to know what standard rims fit which cars.
I found bits of info across numerous threads...but more often questions eg whether R32 GTR wheels fit R33 GTST etc etc without answers
It would be useful to build a reference of what standard wheels can be interchanged with different models assuming stock brakes and tyres.
(edit : formatting doesn't work - I'm trying to show a table of what wheels will fit other models)
standard wheels (fit)
R32 GTST (???)
R32 GTR (????)
R33 GTST (???)
R33 GTR (???)
R34 GTT (R33GTST, R32GTST (with 3mm spacers))
R34 GTR (???)
Stagea (??)
GTS models (??)
If people provide the info I'm happy to collate into a table.
cheers
Mike
all wheels will fit a R32 GTS-t, the GTR ones may need u to roll ur guards, same with GTR wheels on all GTS/T's.
GTS wont fit obviously as they are 4 stud, unless they are type-s, type-s wheels will clear rear calipers but not front.
R34 GTT wheels didn't fit over my standard R32GTSt TypeM front brakes.. there is a little dip in between the spokes on the GTT rims that bound up on the calipers, needed 3mm spacers to not bind.
As soon as I put 33 brakes on, no longer required the spacers as the calipers sit a little further out from the centre and cleared the dips in the GTT rims (by less than 1mm lol)
    • My crystal ball says that when they replaced the pads, they didn't replace all of the brake hardware (could be a missing shim, pin, spring, etc).  Finding a low dust pad should be very easy. Have a google for things like, low dust / soft pad compound / easy on rotors. Your dust primarily comes from the rotors getting eaten up by the pads.
    • I think old mate is going to continue to hold out for awhile at that price
    • OBD1 is a catch-all term for pre-OBD2 which could have basically any connector design and protocol. I really don't understand this attitude against using data logging for issues that can be multi-causal and subtle. A no-start situation or something like that sure the scan tool does nothing but if it runs like shit it can often be a sensor issue. When a friend of mine reliably had issues with his N54 not able to stay running eventually I narrowed down the issue to a faulty fuel pressure sensor. Only way I could do that was a scan tool to look at the fuel rail pressure and see shadow codes for fuel pressure. Then check against a pressure gauge. Is reflexively firing up the data logger probably a bad habit? I guess, it can encourage people to not listen/observe but on these old OBD1 cars just taking a log really doesn't do anything by itself. You still have to synthesize everything you know and think about what it all means.
    • https://www.carsales.com.au/cars/details/1999-nissan-skyline-gt-r-v-spec-bnr34-manual-4wd/OAG-AD-24005316   i reckon some former Skyline owners are wishing they held out a little longer before selling up?
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
