how ya going guys,
just wondering how ya decide on a set of cams for ya car. if there is like a guide on how each different duration would affect the car, i was told that there is a book for v8, when people are looking at cam selection. just wondering if there is anything like this for imports, or more so rb engines, even more specific, rb26's?!?!
thanks guys
James
https://www.sau.com.au/forums/topic/247457-cam-selection/
surely someone can point me in the right direction??? i know everyone is going to have a different opinion. i woiuld have thought this would have been a large interest point with building up hi po rb26's
https://www.sau.com.au/forums/topic/247457-cam-selection/#findComment-4298564
need some more info dude
cant reali just recommend a cam with out knowing specs its very important u match the size of ur cams to the size of turbo ur using
by looking at ur signature it only looks like ur running R34 GTR twins so i would go stage 1 but if ur planing on changing the turbo's to some thing bigger later on down the track then thats a different story
Edited by STR8E180
https://www.sau.com.au/forums/topic/247457-cam-selection/#findComment-4298869
i am running 34 gtr ceramic turbos atm, but im looking at either the garrett gt2860r -5(the hks gt-rs equivilent?) or a garrett t04z/r(would you know the part number by off chance for that turbo mate?) upgrade.
i was looking for a nice lumpy idle, good mid range response right thro to the top end say 8500rpm. specially caus ethese turbos are bigger than stockies
https://www.sau.com.au/forums/topic/247457-cam-selection/#findComment-4300159
is there any beinift in using different duration in the in and ex sides? as i hav seen some hipo gtr's in japan running the different durations on each side
i was looking around the 260ish-270ish but wasnt really sure on how this would help me with what i wanted, so i thought i better ask!!
i have a built motor, with 20thou over. so slightly over the stock capacity, if this can help. also i have a set of adjustable cam gears on the car but havnt been dialed in yet, waiting for the cams.
how would the car react with the cams in on the r34 gtr turbos? b4 i start plaing around with my turbo set up???
also what kinda lift can the stock head gear handle, and when should i start replacing the springs and other componentry???
cheers
James
Edited by Turbz_13
https://www.sau.com.au/forums/topic/247457-cam-selection/#findComment-4300872
Need more info like what future mods your going to do to that engine .
Many think that Tomei Poncams are a good bolt on (in) and they seem to work well .
Personally I would stay away from wild cams in a mechanically std road engine because they aren't driven at high revs for long enough to make them worth the grief .
Your call but I don't see a lot of value in a lumpy "idle" , it's usually a sign of bad tuning or reversion and by nature these are not what I call desirable characteristics .
If you had financial and time freedoms I think a well ported head and mild cams would give good all round results but cams alone get you part of the way there .
I'd look at Poncams , cheers A .
https://www.sau.com.au/forums/topic/247457-cam-selection/#findComment-4300875
I think when choosing cams you need to take everything into consideration
Rev Limit
Gear Ratios
--These come together, to find where you're at on your upshift
Turbo
Cams
Combining all these, best turbo for early spool to bring you all the way to your rev limit
You may not need a high rev limit if you're upshifts bring you to a sweet spot so you can opt for an earlier spooling turbo
Then based on where that sweet spot is, cams with duration to suit that rev range
I would do that for track anyway, drag and stuff would probably be a bit different
I think this post gives a good fairly general guide of durations
http://www.skylinesaustralia.com/forums/in...t&p=4002120
The answer on duration depends on what RPM range you are targetting, be realistic. If you intend to use 7,000 to 9,500 rpm, something around 272 to 288 degrees would be the go. For 5,500 to 8,000 rpm, around 260 to 272 and for 4,500 to 7,500 rpm then 248 to 260 is the go. That's a simplification, but you get the idea. As for lift, once I know the effective rpm range, I then choose the highest lift I can for that duration. What valve springs you are using will also determine the maximum lift.
Cheers
Gary
https://www.sau.com.au/forums/topic/247457-cam-selection/#findComment-4300960
Ive got a Built SR20 in one of my S13's revving to 9krpm with T67 turbo and i run Tomei 270's. Idle is somewhat lumpy but nothin too bad. Powerband is strongest from 5k-8500rpm. I imagine the 270's for the RB will be similar.
http://www.youtube.com/watch?v=syNqwlcebrw
https://www.sau.com.au/forums/topic/247457-cam-selection/#findComment-4301149
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
