how ya going guys,
just wondering how ya decide on a set of cams for ya car. if there is like a guide on how each different duration would affect the car, i was told that there is a book for v8, when people are looking at cam selection. just wondering if there is anything like this for imports, or more so rb engines, even more specific, rb26's?!?!
thanks guys
James
https://www.sau.com.au/forums/topic/247457-cam-selection/
surely someone can point me in the right direction??? i know everyone is going to have a different opinion. i woiuld have thought this would have been a large interest point with building up hi po rb26's
https://www.sau.com.au/forums/topic/247457-cam-selection/#findComment-4298564
need some more info dude
cant reali just recommend a cam with out knowing specs its very important u match the size of ur cams to the size of turbo ur using
by looking at ur signature it only looks like ur running R34 GTR twins so i would go stage 1 but if ur planing on changing the turbo's to some thing bigger later on down the track then thats a different story
Edited by STR8E180
https://www.sau.com.au/forums/topic/247457-cam-selection/#findComment-4298869
i am running 34 gtr ceramic turbos atm, but im looking at either the garrett gt2860r -5(the hks gt-rs equivilent?) or a garrett t04z/r(would you know the part number by off chance for that turbo mate?) upgrade.
i was looking for a nice lumpy idle, good mid range response right thro to the top end say 8500rpm. specially caus ethese turbos are bigger than stockies
https://www.sau.com.au/forums/topic/247457-cam-selection/#findComment-4300159
is there any beinift in using different duration in the in and ex sides? as i hav seen some hipo gtr's in japan running the different durations on each side
i was looking around the 260ish-270ish but wasnt really sure on how this would help me with what i wanted, so i thought i better ask!!
i have a built motor, with 20thou over. so slightly over the stock capacity, if this can help. also i have a set of adjustable cam gears on the car but havnt been dialed in yet, waiting for the cams.
how would the car react with the cams in on the r34 gtr turbos? b4 i start plaing around with my turbo set up???
also what kinda lift can the stock head gear handle, and when should i start replacing the springs and other componentry???
cheers
James
Edited by Turbz_13
https://www.sau.com.au/forums/topic/247457-cam-selection/#findComment-4300872
Need more info like what future mods your going to do to that engine .
Many think that Tomei Poncams are a good bolt on (in) and they seem to work well .
Personally I would stay away from wild cams in a mechanically std road engine because they aren't driven at high revs for long enough to make them worth the grief .
Your call but I don't see a lot of value in a lumpy "idle" , it's usually a sign of bad tuning or reversion and by nature these are not what I call desirable characteristics .
If you had financial and time freedoms I think a well ported head and mild cams would give good all round results but cams alone get you part of the way there .
I'd look at Poncams , cheers A .
https://www.sau.com.au/forums/topic/247457-cam-selection/#findComment-4300875
I think when choosing cams you need to take everything into consideration
Rev Limit
Gear Ratios
--These come together, to find where you're at on your upshift
Turbo
Cams
Combining all these, best turbo for early spool to bring you all the way to your rev limit
You may not need a high rev limit if you're upshifts bring you to a sweet spot so you can opt for an earlier spooling turbo
Then based on where that sweet spot is, cams with duration to suit that rev range
I would do that for track anyway, drag and stuff would probably be a bit different
I think this post gives a good fairly general guide of durations
http://www.skylinesaustralia.com/forums/in...t&p=4002120
The answer on duration depends on what RPM range you are targetting, be realistic. If you intend to use 7,000 to 9,500 rpm, something around 272 to 288 degrees would be the go. For 5,500 to 8,000 rpm, around 260 to 272 and for 4,500 to 7,500 rpm then 248 to 260 is the go. That's a simplification, but you get the idea. As for lift, once I know the effective rpm range, I then choose the highest lift I can for that duration. What valve springs you are using will also determine the maximum lift.
Cheers
Gary
https://www.sau.com.au/forums/topic/247457-cam-selection/#findComment-4300960
Ive got a Built SR20 in one of my S13's revving to 9krpm with T67 turbo and i run Tomei 270's. Idle is somewhat lumpy but nothin too bad. Powerband is strongest from 5k-8500rpm. I imagine the 270's for the RB will be similar.
http://www.youtube.com/watch?v=syNqwlcebrw
https://www.sau.com.au/forums/topic/247457-cam-selection/#findComment-4301149
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
