I'm selling my trimatic conversion to suit RB (off an RB30)
Box was originally built by Hugo's Raceglides back a few years ago, and freshened up by Dave @ RVO when I bought it earlier this year. - probably done only about 1-2,000km since. Box was built with 300+rwkw in mind and is fully manualized with extra clutches, fancy input shaft and all the other goodies done! - has run 10 sec passes before.
Unfortunately the box is in need of a rebuild after getting a bit too hot :) (it's now making crunching noises in fwd gears) - not sure what is involved in the repair, but the car wasn't driven like this at all, and there was no dramatic bangs or anything - just crunched in gear, put on a truck and towed home. - Then pushed up a curved uphill driveway with a spool :*(
This comes with a billet TCE 4800 stall converter to suit! - converter is nice and 'tight' and didn't really "drag it's arse" around on the street!
Also comes with a B&M trans cooler (7x10" I think?), lines, a B&M pro-ratchet shifter, bracket, cable, front half of tailshaft (suit commodore), crossmember (suit commodore), dipstick etc - all you need to convert to a trimatic! - Can also supply a stock flexplate at no extra cost, or if you wanna get fancy I have a fandangle billet CNC'd flex plate for an extra $350.
The auto has a custom made speedo fitting that uses a stock r31 speedo sender unit.
By the time you pay for a rebuild you're still way ahead the usual asking price for these, and you have a brand new auto :(
I'm selling as I want to go with a manual (r33 5spd) - Otherwise I'd be rebuilding it and putting it back in :) - will gladly consider swaps for a manual setup or some kind of deal like that.
Happy to freight at buyer's expense - and can do a COD style service at buyer's expense as well (pending small deposit) - quote for courier can be arranged.
Also happy to separate at this stage - make an offer for pieces, or $1700ono :) for the lot
PM or email me <removed>
And now that story time is over, here's some pictures:
Edited by Duncan
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
