I'm selling a R34 Nur long motor. It's still sitting on the create that it shipped in from Japan.
I had planned to put it into my R32, but my father has developed brain cancer and so spending cash on toys is now not a priority.
Item
R34 GTR NUR RB26 Engine
- Long Motor
- Race Bred
- Strengthened Internals
Long Motor Includes:
- Front Diff
- Front Sump
- R34 NUR Timing Cover
- R34 NUR Cam Covers
Engine Specifications:
Displacement: 2568cc
Bore: 86mm
Stroke: 73.7mm
Compression: 8.5:1
Block: N1 (24U stamped on block)
Pistons: N1 (Precision Balanced NUR Spec)
Conrods: N1 (Precision Balanced NUR Spec)
Oil Pump: N1
Water Pump: N1
More info here : http://en.wikipedia.org/wiki/Nissan_Skyline_GT-R#N1_engines
Price: $8000 firm.
Contact: PM me
If only you had this for sale this time last year :S would suit the colour of my car and have suited my budget marvelously.
good luck with sale.
might repaint my engine....
Ohh shiii thats not good news! i was wondering what was happening with you and your motor, i've still not got around to mine yet.... i wish you and your family all the best ;)
Bargain. These are like 13k to buy here.
$13k is for a new one, this is used by the looks of it... rear of the head and block has surface rust (leakage) and front cam cover looks scuffed from angle sensor wiring.
hey i had a customer just ring chasing an engine for his newly bought and blown R34 GTR, whats your contact details?
Edited by URAS
im interested in your engine - i'll come back to u once i have a chat with my mechanic, i too want to know what these engines can hold compared to a forged bottom end...
probably not the time or place to post this but i lost my father 3mths ago from bowel/liver cancer at the age of 61...i know what you are going thru & to be honest there is nothing to say & nobody can explain this heartache...i am struggling will continue to struggle with my loss for a very long time - all the best to your dad & your family from the bottom of my heart -
edit: forgot to add that if u want to talk to stranger (marko) about your position & also loves nissans, my number is 0404 884 876
Edited by Marko R1
Looks pretty new to me. My money is on surface rust from sitting in a damp garage - I mean look at the spark plug holes...
Has anyone asked the seller?
i'm 100% sure its new!! we were chatting about our plans as i also bought in a r34 N1 motor myself around the same time he did..
were both discussing build plans and such
Andrew
Motor is not new but still in very good nic from what I could see last week. Sump has been taken off most likely for baffle plates. Cam lobes, you can hardly see any wear marks.
Still great value for an N1 motor.
Edited by mxfly
i send pms and never get feedback or response.... is this really a genuine sale...?
Well I did goto his place last week and yes, the sale is for real. I think you have to consider that he might not be online all the time, considering his dad's health atm.
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
