Hi all,
Hoping to get out to pick up some exhaust gaskets on my lunch break today and I know that the ID is 275mm but I don't know the ED/bolt spacing... can anybody help out at short notice? ;)
thanks!
DaveB
275mm is like 10 plus inches.?????
lol oops sorry meant 75mm ;) not to worry, went to local motormate/sprint type shops and they "don't have anything that big". So will have to go to an exhaust place anyway... thanks
its a standard bolt PCD anyway just a 2 bolt gasket. i know 2.25" through to 3" all have the same bolt PCD. thats why you can bolt on a 3" catback exhaust to the stock 2.25" cat. the holes are 105mm PCD.
Cheers!!!
I only heard this last night, when I went to pick up a split pipe... the guy told me it would bolt to the standard cat-back for now... that explains it. I held off doing anything about exhaust for so long thinking that I couldn't do anything unless I changed the whole system :S This is very useful info - exhausts are always being modified. Now to find a 105mm PCD gasket with 3"/275mm ID... probably exhaust shop.
Edited by DaveB
Cheers!!!
Hey Dave, that 275 is bigger than a zorst for a Mack truck. Its as big as my cannon diameter.
AAA exhausts on deacon avenue will have them if you can't find them anywhere else
Thanks Mike - that's actually the place I called a while ago about possibly getting a custom cat-back system made up. I'm going to go see them about it when I have the car back on the road.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
