R31Heaven Posted September 13, 2003 Share Posted September 13, 2003 I have read in a couple of places that RB's ingition using double triggers ignition, causing timming lights to show double the actual timming on timming lights, so the unweary mech's turn your timming down retarding it to some weird setting. Is this correct? any info on this welcome... Link to comment https://www.sau.com.au/forums/topic/24762-double-trigger-on-timming/ Share on other sites More sharing options...
crooser Posted September 13, 2003 Share Posted September 13, 2003 if the timing light pickup is placed on the wire in the reverse direction, you get a reading much higher than you should. this is the only wierd thing i have seen with some rb25 engines Link to comment https://www.sau.com.au/forums/topic/24762-double-trigger-on-timming/#findComment-527209 Share on other sites More sharing options...
R31Heaven Posted September 13, 2003 Author Share Posted September 13, 2003 My Autelec was using a profesional light, the wierd thing is that he retarted the CAS fully and his light showed 18 degrees Link to comment https://www.sau.com.au/forums/topic/24762-double-trigger-on-timming/#findComment-527215 Share on other sites More sharing options...
