Lookin to buy a car and had a compression test done by performance place and just wondering if anyone can give me some advice. ill update the exact results for each cylinder later but on average no higher than 170 and no lower than 150, i think was somethin like 170, 170, 150, 160, 155, 150
like i said ill update bit later, but thats basically what i remember? was told its ok, then told its not any help please????
Thankyou!!
https://www.sau.com.au/forums/topic/247656-compression-results-on-34gtt/
You get different readings depending on the battery and a few other components. I believe 150 is standard but the higher the better they say.
Of course they must be consistent with each other.
If there not identical to each other move on to another car until you find one that is.
You want it to be spot on
the other thing is you really need a leak down test also.
When i had my 100km service the compression was 170 170 170 170 60 65, since the car is pulling max power for the mods i was like wtf
Turns out i just had a heap of carbon build up in the intake.
Test after was 170 170 170 170 170 170
Ok results were As follows:
CYLINDER 1- 170PSI
CYLINDER 2- 170PSI
CYLINDER 3- 160PSI
CYLINDER 4- 150PSI
CYLINDER 5- 155PSI
CYLINDER 6- 160PSI
Guy from the workshop said car runs smooth as a babys behind. and really seems like the guy doesnt thrash it, middle aged and very particular owner and mechanic said car is very well looked after. then again u never kno what happens in japan. Im gona ask for a leak down test I think to be sure. what u think?
Edited by 1R34SON
When I bought my car, I had a clause on there, which was I can return the car if my mechanics testing showed the engine was not in good condition.
Did a dry compression test: 1 - 176, 2 - 175, 3 - 177, 4 - 176 , 5 - 177, 6 - 176
Did a wet compression test: 1 - 177, 2 - 177, 3 - 176, 4 - 177, 5 - 178, 6 - 178
The minimal difference in figures means that it was great compression to start with, and after using some oil to further seal the rings, the figures where almost the same (there is a variance in or 3 - 5 psi in the gauge I used). Considering the figures where almost identical, it means there is no pressure loss on the rings, meaning any pressure loss is in the valves.
a Leak-down test revealed the pistons hold very good pressure, meaning the valves are not loosing pressure, and the engine is in good condition.
Did a radiator pressure test as well, revealed no issues, did an intake pressure test, no boost leaks or other leaks,so I rang the previous owner and told him to go nuts with the money, I wasn't disappointed with the tests at all.
I later found out from a relative of the previous owner that the engine had blown, and was completely rebuilt from the ground up, forged pistons, rods, balanced crank, all the oil mods to the head, sump baffles, N1 turbochargers, etc. The works has been put into that engine to make it bullet-proof (as bullet proof as an RB26 will get), but then he had to sell for family reasons.
If you get a good RB engine, and you let them warm up before revving them and thrashing them, keep good oil to them, and dont rev them over 7,000rpm (unopened), the engine should be good for a lengthy life.
It's the other bits you need to worry about, gearbox, diff, suspension, rust through the body, but someone who knows cars will be able to pick if they have been in an accident, or if they are riddled with car-cancer.
My only advise: Dont fall in love with a car while looking, treat them all as damaged stock until you find the perfect one, and once you have purchased it, you can fall in love. (I fell in love with a 180sx yrs ago, wanted it no matter what so I wasn't maticulous in checking it out. Later found a 1 inch rust spot, took the screwdriver to it to brake all the rust out before welding a plate to the car, and the hole was 1 inch, but the rust through the panel was 1 foot 2 inches, it was HUGE!!!).
B.
Again - as stated earlier... its the % difference not the actual numbers more than anything.
Obviously if it goes
160 150 155 160 150 80
Then you have a problem, but if they are all near enough to the same number, its fine and a good result.
If you want a much better TEST - Leak Down test is the one your after
spoke to a guy from a turbo engine tuning workshop and told me this same thing ^
he said that numbers will usually vary. and as long one isnt out by heaps or under 150 its fine. cheers all!
When I popped my stocker, it went:
Cyl 1/ 0
Cyl 2/ 75
Cyl 3/ 150
Cyl 4/ 150
Cyl 5/ 150
Cyl 6/ 150
See if you can guess which piston had a broken ringland and which had lost ring tension.
I'm guessing Cyl 2 had a broken ring land and your ring lost tension when you realised the motor needed a rebuild :(
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
