Today I jis purchased Motul Turbolight 4100 after a few mates recommended it, as soon as started my baby was the whole engine began to shudder, it settled down after reaching temp (which is at exactly half, same as previous oil) however when driving under 2.5 - 2K revs would still shudder, my presssure has dropped also to below 4, and wait for it, turbo doesnt boot in at all, jis feels gutless and runs ruff as rocks. What would be the best thing for me to do to fix this?
Thankyou.
https://www.sau.com.au/forums/topic/247679-argh-motul-turbolight-4100-wtf/
  • Replies 44
ay mate, i noticed when i used motul my pressure was always really low, 2-4, so yeah not the only one out there, it used to sit on 6-8 with castrol edge
best way to fix, dump oil, put different brand in, if problems persiste see your mechanic asap
did you accidentally put cooking oil in it???? depending on modds and all that but no motor oil should do that..... change the oil and see what happens.... other than that it does seem to have similar symptons to a spark problem with the info you gave.... i'd check that if the problem doesnt go away
Some experts on oil in this thread i see....
There is nothing wrong with turbolight, and as for being a semi-synthetic, most oils are actually semi-synthetic, even if it says "Synthetic" on the oil, it doesn't mean it is 100% synethetic. But thats another topic. Back to the original problem.
What your describing has nothing to do with the properties/brand of the oil, its a 10W40 for the record. What else was done to the car at the same time as the oil? Spark plugs changed?
ive used it before and no probs. true that oil pressure is lower but i cant see it being the cause of your problem though. did you do anything else when you changed your oil like sparks, fuel filter and stuff. they would more likely be the culprit than the oil in my opinion.
Yea.. thats y I recommended 300v and mobile 1 supersyn, since they are 100% synthetic. i.e. group 4, 5 synthetic base. Not sure about royal purple thou. 4100 is probabaly group 3 and group 1 oil mixed together, fine if you use it in camery, but no way in hell i'll put that in my skyline.
did you spill some into the coilpack area?? i second that no oil can do that on its own.. only if it gets in somewhere its not meant to, or its soo thin that its getting into the cylinders..
maybe your turbo seals are kapoot.. thinner oil seeping in there, boost seeping out etc. mine did this when my seals went.
and for the record... i use repsol competion elite... never had a problem.. $68 for 5L.
Edited by NZM.031
Yea unfortunately I filling up the oil was the only thing i did to it at that point, so kinda makes me think that maybe my turbo seals have blown or something >.< however i didnt drain the previous oil remainders out, wouldn't have been much :) but yea should i have done this? yeah it seemed to want the whole 2 litres of the motul and well i will have to drain the motul out n e way, is the bolt hard to get too? i fear i may to jack it up
it should take about 3.8-4.2L of oil. when you mean remainders, you did drain the old oil out first yeah? Your asking if its hard to get to the bolt which implies that you didnt change the oil at all, you just filled 2L of motul in with the old oil. Thats a lot of oil to pack in. when i bought my turbolight it came in more than a 2L bottle. Did you change the oil filter too?
sounds like you didnt do a proper oil or a service for that matter to me...thats how I'm seeing it from what you've said.
The sump plug bolt isn't at all hard to get to. I can get at it without jacking my car up (stock ride hight). If your car is lower you might need to jack it up, but it would still be easy to get at.
Nothing wrong with 4100.
I have done many oil changes with it. Pulled engine down for a rebuild and the engine was in perfect condition. As long as you do an oil change every 5000km its perfectly fine.
there is no engine oil on the planet that can cause ur motor to run like that. unless u did something wrong. did you even drain the old oil completely includint the 500ml or so that is in the oil filter. if u are going to do an oil change u need to do it properly or there is no point in doing it. i usually change my oil every 5000km and have had no worries. i even put a very heavy 25W-60 in one day to see how the enging would behave. nothing happened but the oil pressure was higher.. it sounds to me like u just topped up the oil that was alreeady in there with new oil. probably massivley overfilled the sump causing windage. where the crankshaft hits the oil and churns it up. if u drained the oil and only put in 2L ur in trouble.. put more in ASAP and check ur dipstick. that is what it is there for.
Yea unfortunately I filling up the oil was the only thing i did to it at that point, so kinda makes me think that maybe my turbo seals have blown or something >.< however i didnt drain the previous oil remainders out, wouldn't have been much :banana: but yea should i have done this? yeah it seemed to want the whole 2 litres of the motul and well i will have to drain the motul out n e way, is the bolt hard to get too? i fear i may to jack it up
ummmm so you had all your oil in the car (4.5-5L) and then added 2L of Turbolight into it.........?
Where is it meant to sit? mines sitting between 3-4 but seems fine? now im confused!
Thanks for all the help so far guys, unfortunately i have been a ford (cough cough) person my whole life until now so im not too mechanically familiar with my baby >.< having serviced at the mechos, does sound like i have overfilled it a bit, obviously my dipstick is accurate, my pressure had been sitting low for a while and it sounded a lil rough, problem is obviously with something else and i may have jis made a new one yay.
I noticed an oil leak dripping from near edge of the cooler this morning, so kind makes me think yea its overfilled.
PUDZ you were saying .. "it sounds to me like u just topped up the oil that was alreeady in there with new oil. probably massivley overfilled the sump causing windage. where the crankshaft hits the oil and churns it up".... windage does this cause a bit of a shudder at times if this is what u are refferring too?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
