Up for sale is my bros R32 gtst. Just finished servicing and fixing a few things these last few weeks. Finished it all and decided to give it a wash, thats when all hell broke loose.
Just a few hours after, that massive storm that hit SEQ a few weeks ago decided to persuade a tree to fall on it, cracking the windscreen and hitting the roof. He doesnt have the funds at the moment to fix it, so he's just seeing if theres any interest in it as is. He is looking for around the $7,500 mark but is open to offers. He might strip it at a later date if theres no interest. It is still registered to June 2009. Below is some info and pics to show what I've done to the car
R32 GTST 1992, 5 spd Manual, 122,000kms
All done within last 1000kms
New Heater Hoses and Worm Clamps
New Radiator Hoses
New Thermostat
New Water Pump
New Alloy 52mm Radiator (Still using Shroud & Clutch Fan)
New Drive Belts (x 3)
New Nissan Radiator Cap (0.9 Bar)
New Engine Oil (Also while Head off, Flushed All Galleries)
New Oil Filter (Genuine)
New Coolant (Complete Flush including Block, Heater Box, Head, Overflow)
New Gaskets (Head, Inlet, Exhaust etc All Genuine)
New Fuel Filter
New Fuel Lines (From Pump to Filter, Return Lines etc)
New Cam, Crank Seals
New Timing Belt
New Idler / Tensioner Bearings, Tensioner Spring
Also has
Injectors Sonic Clean and Flow Tested
Head Shaved, Cleaned, Crack Tested etc
Gearbox and Diff Oils Changed at 115,000kms (Castrol LSX90 in Diff,VXM80 in Box)
Near New Cat-Back Exhaust (10,000kms old)
Near New Clutch Master Cylinder (10,000kms old)
Near New Clutch and Brake Fluid (Changed when Clutch Master was done)
Near New Rocker Cover Gaskets, Half Moon Seals and Bolt/Screw Grommets (10,000kms old)
Hybrid Front Mount Intercooler and Piping
Exedy Heavy Duty Clutch Kit (One up from standard so not harsh at all, installed approx 1 year ago)
Custom Made "Nissan" Gear Stick
Autometer Cobalt Blue Boost Gauge
"MetalCast - Blue" Painted Rocker Covers, Plug Cover, Timing Belt Covers (Top & Bottom)
18inch Rims
4mm on all Brake Pads
Polished Exhaust Manifold Cover, Turbo Cover and Dump Pipe Cover
Mongoose Alarm System
Razo Pedals
If there are any questions or offers please Pm, there are no pics yet of the damage but I will get them
Thanks
post-36458-1228375993_thumb.jpg post-36458-1228376007_thumb.jpg post-36458-1228376025_thumb.jpg
post-36458-1228376039_thumb.jpg post-36458-1228376049_thumb.jpg post-36458-1228376073_thumb.jpg
post-36458-1228376117_thumb.jpg post-36458-1228376124_thumb.jpg post-36458-1228376137_thumb.jpg post-36458-1228376162_thumb.jpg post-36458-1228376176_thumb.jpg
https://www.sau.com.au/forums/topic/247680-r32-gtst/
