Full kit everything needed to bolt it on.
$2650 got sent two instead of one :P full warranty
Edited by URAS
straight bolt onto rb25det neo? cause ill be very interested. location too thanks
yep was going on a NEO :P
Had heaps of PM's asking if it is high or low mount, this turbo bolts directley to the std manifold in the factory low mount position.
STATUS TUNING
63 Rodeo Drive, Dandenong South, VIC 3164
Tel: 03 9792 3333 Fax: 03 9792 5555
Mob. 0414 944 146
sorry should note that this thing will pump well over 300rwkw with moderate boost, i listed it as 250-280 as that what most guys get with 15-17psi.
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
