ok, as I said I don't push my car hard on road, I drive carefully and slowly in wet. Maybe it got something to do with the suspension, the Buddyclub N+ has a quite stiff spring rates, front 10, rear 8.
ouch at that pickup truck pic.
I know where your coming from and its not really your driving style like others have pointed out. Its your setup, thats all. Stiff suss wont see you going sideways unpredictably at really low k's but it is one of many factors, your camber, your tyre, and the amount of surface contact. get em all sorted out and you should have no drama other than your right foot. I addressed these issues and the problems gone away and I'm still running my stiff tiens.
next time it happens, just stick your hand out the window and yell out
"DDDDDDDOOOOOOOOORRRRRRRRRIIIIIIIIFFFFFFFFTTTTTTTTOOOOOOOO!!!!!!"
KOOOMANNNGIII ATTACKKKKK!
srsly tho, i run the same tryes (dunlop lemans lm702 245/40/18) and with 5/7 coils, struts, sways, castor, camber, hicas lock and 265rwkw i'm fine...
it's ALL in the driving, not the car
Ahem
the car starts to "Drift"....sometimes in a hurry right turn
Thanks for coming.
I've driven a modified 5.0L Commodore SS auto with Goodyear F1s on the front and retreads on the back in the wet, and managed to not spin out. I can guarantee that car would have less wet weather rear grip, and a shedload more torque that is a lot less predictable in its delivery.
I don't have the castor, camber kits, I will get the camber kits see if make a different, if it still does the same thing, then i must be a bad driver
Coilovers are a contributor to this, i also had to much camber as i was running 18x10's with a big ofset, granted it was very fun coz all i had to do was turn the wheel in the wet and it would slide out nicely no matter what tyres i had on there... also having a light tuned RB26 mad the slides last :P its just a fact of life with these sorts of cars especially with coilovers +to much camber. its no fun to just putt around doing 20 in the rain so let it slide and just enjoy the ride
Its in the right foot......plenty of people drive around with this sort of HP at the rears only ( My VU ( ss ute ) is 700hp and over 1000nm rear wheel drive and not much weight in the back without the spare etc.... was a brilliant car to learn propper throttle control especially in the wet biggest issues where making a turn out of a side street uphill in the wet the rears would just spin and spin and it was almost impossible to get traction but after some proper practice and some forced self control....... it drives fine.
Tuning and changing your suspension may well help but learn to control what you have got appropriately first....
    • Ha ha, yeah, I've had one following me around in my parts boxes since about 2007 I believe. Just a little iddy bit hole drilled in the one I have to let it vent out once pressure was removed from the engine side. Still no idea what I'd put it on, ha ha.
    • Just read this... Just a little bit of a wild one! Do you think the driver was testing out a new feature/device for how to lose the cops in a high speed chase?   I also suspect, if the box has a road sweeper that does magnetic metal pick up, he does a LOT of work in the machining industry. Which is what most of that looked like, machining chips from a mill or lathe. And I bet they're RAZOR sharp! And from an environmental perspective they really do need to actually collect all of those little pieces too. I wonder how many people still cop flat tires over the coming months on that road?   As for insurance company, yeah, it'd be interesting to hear what they say to the owner. But realistically, he's right, that "It's his fault". In the way that, it was his truck that spilled it, so they need to clean it up. However, neither he, nor his insurance company may bear the end cost if they do an investigation and find out it was caused by someone elses negligence (And they know who)...
    • Yeah, no matter what bad things people can say about Julian from Autospeed, he at least was capable of thinking and his inclusion of a check/relief valve in the plumbing for the Audi boost controller, that I made a copy of and used for years**, completely eradicated that problem. **It's still lying on my workbench where I put it about, um, 18 years ago and have never found a home for it!
    • I didn't actually know this! I've seen photos of the H1, mainly outside shots, and they just look "different". I guess there'd be a few little changes like nicer rims, and probably the fact they have nicer looking paint with some depth and shine, which will make any vehicles body look different to the very flat colours of the defence force.   I've watched the guys on GHPC convert their Humvee to LS1, and they've done some really nice front shock upgrade. I'm waiting for the next video on it with the rear end done. I can't remember if they've already done it, or I dreamed it, but I believe they're also supercharging theres. They will be in the future doing proper long travel suspension too.   If you ditch out your big V8, as rubbish as it must be, send it to my place. I'll let the unreliable V8 motor and box be here. I just like V8s... So I'll find something to do with it... Even if that something is just taking up valuable space in the yard. I might have something Skyline I can send back in payment... Or even Ford Barra motors  (From memory you're in Canada yeah?) So you can then play with the legendary Aussie 4L version of an RB...  Except they don't have that distinctive random miss at idle like the RB25 does.
    • Or you mean the age old problem of early 2000's manual boost tees, where they never let the pressure out of the line between the boost tee, and the waste gate, so after your first trip on boost, the damn wastegate liked to stay open and be laggy on gear change?
