First step is to head on down to a field when training is happening, with our first tournament in March I assume we'll begin training early next month. Trainings are on Sundays from 10am up at Action Paintball Games in Serpentine.
Head down, check out some gear, meet the ppl and get involved :3some:
Setting up a team isn't easy (which is why I'm not our captain :3some:) so unless you have 4-5 mates who are super keen then you're better off just getting kitted out, training up and broad minded femaleting out to teams. There's always teams looking for players leading up to a tournament and you might land a fulltime spot :3some:
If anyone is keen to give tournament paintball a bash, I have enough gear to kit you out for a training session to give you a taste :3some:
Edited by bubba
  • Replies 99
  • 1 month later...
  • 1 month later...
I do pro wrestling, not really a "sport" though more just physical activity.
Used to play all the standard ones back in the day though cricket, soccer, football etc. I really should play soccer again this year.
hey dude, mate just sold his boat,
but usually belmont ski area or waroona dam.
you wakeboard?
Hey yup, we borrow a boat and head to Waroona as well or Bonney's ski park. That's a real shame the boat's gone... :D
I have to admit I land on my head more often than my feet so it can't really be called wakeboarding......
Bubba, hard to recognise people covered head to toe and then painted, but are you talking about Russ? He said he knew you when I talked to him last.
Hey yup, we borrow a boat and head to Waroona as well or Bonney's ski park. That's a real shame the boat's gone... ;)
sweet! Since im without a boat have to take me for a pull one day hey!?
I wakeboard and skii as well.
Good fun.
Where abouts do you guys do it?
Im mostly just down on the swan river.. near mt Henry bridge.
Well, I still don't have my skippers ticket...so I can't drive if we're on the river. We usually go to Bonney's or Waroona.
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
