just had the rear bar and side skirts fitted ... fittment is pretty decent (rear bar almost perfect, side skirts a bit iffy but passable) however the spray painter butchered the whole thing.
It is THE worst paint job I have seen in a very long time. There are dropplets, streaks etc all over the bar and skirts .. like a hundred of them and a couple of really big ones. The rear bar looks wavy/bumpy that's how shit the paintjob is .. on a scale of 1 to 10, the paintjob is a -25 I reckon I could have done a better job with a bit of sand paper and a paint brush.
"luckily" I was rear ended recently and insurance is paying for the repairs and I'll get the smash repairer to respray the new rear bar instead of the old factory one. I might have to pay to have the side skirts resprayed though because the paintjob is an absolute joke.
Edit: carmate offered to have the rearbar (but not sideskirts which are just as bad) resprayed in about a month, what a joke. No way I'm taking it back to the same spraypainter.
Edited by Delta Force
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
