I will post pictures as I’m progressing here’s pick up and starting the tear down IMG_7166.mov
My G35-900 1.06 T4 result on HKS 2.8 stroker https://ibb.co/VD2qT1r https://ibb.co/NSgqK76
Care to explain the thinking behind this question?
how come someone says, this isn’t a car that should be out on the road right now.
That's not going to happen, given... Because that shot should be categorically impossible. Stock circuit goes direct from dash switch/dimmer to globes. Someone might have added relays and f**ked that up, so that the relays stay on regardless of the control side being on/off/unplugged. There's a big 3 pin connector (H4 style) behind each headlight that carries the Lo, Hi and earth wires, that plugs into a subloom that breaks out to connect to the separate Lo and Hi globes in the headlight. If there are relays added, they should be there, because it is the easiest place to intercept the stock wiring and interpose something else.
