Holset Turbo's
R31 forum is ran literally on a tiny budget with 1 volunteer. I'll check and see if we can get it back online.
Everything has to go into the ground to return to the molten layer below us eventually.
I'm with GTS, that's not an actual overheat issue. That's an electrical issue.
So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
