That was a really fast reply! Thank you very much. i will contact kelford. Have a great day
Lifters (solid vs hydro) do not affect VCT. For cams, just contact Kelford in New Zealand and tell them what you want to do with the engine and that it is a solid converted 25. They'll know what to give you. FWIW... you can probably use any cam with either hydro or solids at that power level. By "any cam" I mean, there probably isn't a particular reason for the profile to be much different between the two.
Hello from Germany, i build my RB25DET Series 2 -> Target 600hp i have now ordered solid lifters from Tomei for the cylinder head and will replace the original hydraulic lifters. Which cams can you recommend ? It is only a street car.... Maybe i order a Garrett GTW38 or something like that. and what is with the VCT ? is it blocked with the solid lifters ? Attention is a RB25DET with solid lifters! Thank you for your help
By robbo_rb180 · Posted
Diff arrived from Japan last week. Nismo gt pro 1.5way for gtr. Still deciding whether to use 4.11 or 3.9 gears before installing. Spent some time yesterday going over what's needed to finish engine bay fuel lines. Got a list so will order soon. Played with radiator placement and decided on stock location with bottom spaced a bit for a small amount of angle. So ordered standard mounts and rubbers. Reason for this is the 180sx was a pain to work on any of the coolers and was also going to take longer to fabricate mounts. Today made a bracket to mount the dbw throttle pedal. Factory location wasn't great to work with the pedal box. Luckily there's a rail that pedal box mounts too so did some measuring, drew up a design and got stuck in. It's made of 3mm aluminium and has a lot of strength just need some bolts, washers and nuts to finish up. If I get time tomorrow I'll pull the front bar and lights to start intercooler mounting, it will be flipped under the rad support which will require some trimming.
