As I understand it, the main reason for using a turbo timer on a turbo'd motor is to give the turbo's a little time to spool & cool down before stopping the flow of oil to them.
I personally can't see any reason for a turbo timer on a N/A, except for trying to mislead others into thinking you car is turbo'd!:P
anycar would benefit from a cooling down, but its not as needed in NA cars, i think the Apexi turbo timers (some of them) have TUrbo and NA on their packaging....Rice factor for NA cars.
Turbo cars should cool down because the turbo runs very hot, and oil is needed to extract the heat away. Leaving the car in idle allowes the oil to circulate through the turbo
if your going to put a turbo timer in a n/a , F*uck off the Apexi shit not worth the $$, go to jaycar and get 1 for $20 that u make your self that keeps you car running for 30sec after u turn it off.
personaly it's a rice factor for n/a cars.
but i would do it coz i'm rice
(chicks may think it's cool, i dont know)
haha its ok guys i was never actually considering getting one, waste of money and completely unnecessary. i was just curious if there was a reason for it saying on the package "for turbo and n/a models" - like if there was any benefit in running a non turbo car for a bit after you stop. i usually run it for about 30 sec after i stop just while i grab shit off my back seat, tidy things up a bit etc
anyway thanks for the replies :)
I use my turbo timer to warm up the engine, b4 driving.
Turn the engine on, set timer for 10 min, take keys out, lock doors, go back inside house, get ready to go out, eng. is nice and warm and has suffered the least stress. (most wear and stress on an eng. is caused with-in the first 10 min.) If i take longer to get ready, the eng. turns off, but will still be at full operating temp. by the time i get in the car.
PS: Don't forget to put the key into the ignition b4 putting car into gear. :D
Jimbo2000, i was pretty sure that nos as an oxidising agent, also cools the charge of air as it reacts and then combusts?? therefor the car shouldnt be any hotter? please correct me if im wrong?
  • 3 weeks later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
