As I understand it, the main reason for using a turbo timer on a turbo'd motor is to give the turbo's a little time to spool & cool down before stopping the flow of oil to them.
I personally can't see any reason for a turbo timer on a N/A, except for trying to mislead others into thinking you car is turbo'd!:P
anycar would benefit from a cooling down, but its not as needed in NA cars, i think the Apexi turbo timers (some of them) have TUrbo and NA on their packaging....Rice factor for NA cars.
Turbo cars should cool down because the turbo runs very hot, and oil is needed to extract the heat away. Leaving the car in idle allowes the oil to circulate through the turbo
if your going to put a turbo timer in a n/a , F*uck off the Apexi shit not worth the $$, go to jaycar and get 1 for $20 that u make your self that keeps you car running for 30sec after u turn it off.
personaly it's a rice factor for n/a cars.
but i would do it coz i'm rice
(chicks may think it's cool, i dont know)
haha its ok guys i was never actually considering getting one, waste of money and completely unnecessary. i was just curious if there was a reason for it saying on the package "for turbo and n/a models" - like if there was any benefit in running a non turbo car for a bit after you stop. i usually run it for about 30 sec after i stop just while i grab shit off my back seat, tidy things up a bit etc
anyway thanks for the replies :)
I use my turbo timer to warm up the engine, b4 driving.
Turn the engine on, set timer for 10 min, take keys out, lock doors, go back inside house, get ready to go out, eng. is nice and warm and has suffered the least stress. (most wear and stress on an eng. is caused with-in the first 10 min.) If i take longer to get ready, the eng. turns off, but will still be at full operating temp. by the time i get in the car.
PS: Don't forget to put the key into the ignition b4 putting car into gear. :D
Jimbo2000, i was pretty sure that nos as an oxidising agent, also cools the charge of air as it reacts and then combusts?? therefor the car shouldnt be any hotter? please correct me if im wrong?
  • 3 weeks later...
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
