  • Replies 719
I went up to machine shop this morning to give them a hurry up. They just started back at work after the break. They are close to pivoting centre arms and will have in time and yes. Reason they break is they are loaded as you know they want to go through an arch, and all the arms and bushes on the market only allow to go though one plane and hence they break. They also restrict suspension and act like a stiff shock indirectly, and when they don't they are starting to work lose and then have play in front end. The more camber and caster of a race car accentuates the problem. Odd thing is some cars get away with it with little or no prbos, whilst others have on going problems. All are binding though and restricting travel or free movement of suspesnion.
Awesome work JP...i knew you would be onto it.
The old ones never gave me an issue at the drags...lol
ETA ? and $$
Edited by DiRTgarage
ETA ? and $$
Soon and not much actually, but rather not commit to either yet as third party involved.
As for weight at the time I was half joking but then Bozman would probably only be 65kg maybe 70kg and you guys would be over a cosy 100 kg's. Bozman is Mr Energy and good stuff. Hey Roy good to here lost some beer storage. Is there a VIC team gearing up for this one?
Boz would be OK and quite calm if you didn't make him drink all that 'V' stuff. :)
All the cool kids drink Samedi now paul :)
I seriously can't wait for this, and I'm only spectating! :D
By the way... if someone pays me enough, I'll go around sabotaging competitor cars :)
all it's going to cost you is your car in 1 working piece after the race...
just weighed myself
im a lean mean wippet
139kgs
ill try and get down to my 120 kg fighting weight
ill drive the zed JP... it needs the front end re-modeled
and this thread is shit jp and dirt talking nice to each other is like going to thailand and getting a normal massage... gay!
as i said gay!
who you calling gay....i hear you knock back no women and very few men!
and you reckon your a Rugby old boy...your full of crap!...fatty.
Thats livened it up for ya!
So who is running??
I have been entered to run 3 cars. Looking forward to the improvements on JP's Zed in PRO, Elias S2000 in OPEN and the AWD thing that I am running that has never seen a track in its life :)
I may run my own 6.0 litre in clubman for a stir :D So that could make it 4 lol
Hey Nathan are you around?
I saw this rule in clubsprint class:
• All vehicles entering the Superlap Clubsprint Class must have a full interior. The only exception is for vehicles which have a half cage which needs the back seat to be removed.
I've got no interior trim but the car is still over factory weight (about 1500kg). Can it run in clubsprint?
Nathan you need to answer my question if I am going to enter - I can't enter an over factory weight, standard car in open. But I would be willing to have a fling in clubsprint.
So who is running??
So their goes 2L RWD Open :D Can i tie a bungee chord to the back of the S200 so that way i am at least a chance of second :) Serious question, what do you think the car will do with good tyres?
Not sure Roy as we are changing a few things on it. I hope it can compete for outright open. Will just have to see who and what enters. I have even convinced Elias to put a cage in it :)
What would you rather...a STD overweight car in opens with grip...or the same car in clubman with none ?
    • Yeah, hard to find and a pain in the ass to change with the transverse engine. I’ve worked on a GTiR before and it’s not a job I’d ever want to do again. theres a company in South Africa that makes RS3 gearbox adaptors for the AWD SR20 including gearbox mounts, so I could modernise it and go a dual clutch with paddles. For now tho, it ticks all the boxes. Super cheap, can throw the kids and their junk in the back, and SR20 that I can turbo cheaply, a CVT that’s not a dog’s breakfast like the V35, and has 80% interchangeable parts with stuff I can source from the wreckers cheaply…. But it’s still unique. I love the wagon back of the Autech version. It’s cheap enough that I can buy another stock manual FWD Primera with SR20VE, swap the gearbox to the N15 pulsar short gear ratio box, swap out the brakes to the R32 ones I pulled off my 32, register it on club plates and take it racing. $1300 shipping from NZ. Heaps of parts and aftermarket builders for transverse SR20’s in NZ.
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
